08-16-2022, 12:40 PM | #1 |
Newbie Join Date: Dec 2014 Location: Michigan
| Gatekeeper Builders Kit Shock Caps
What is the size cap needed for the shocks on the builders kit? Looking to upgrade shock caps. |
08-16-2022, 03:25 PM | #2 |
Rock Stacker Join Date: May 2008 Location: 90605
| Re: Gatekeeper Builders Kit Shock Caps |
08-16-2022, 06:54 PM | #3 |
Thanks. But I am wondering size. If I went to amain would it be the 12mm caps?
08-16-2022, 08:19 PM | #4 | |
Rock Crawler Join Date: Jan 2022 Location: st louis
| Re: Gatekeeper Builders Kit Shock Caps Quote:
Sent from my SM-S906U using Tapatalk | |
08-17-2022, 04:23 AM | #5 |
I understand this as well. I have no intentions of "cramming" a random cap onto a shock and perfectly understand diameters and threads. But when i am looking on amain for team associated shocks there is an option for jconcepts 12mm with bleeder. But nowhere does it say they are compatible with the stock shocks. I look at details on the stock shocks and nowhere does it state size. I could also measure the shocks, but i am not sure what the 12mm refers to. OD, ID, piston size... Not sure. |
08-17-2022, 06:07 AM | #6 |
Associated made standard shocks, big bores, and a few others along the way - it does get hairy. 12mm refers to the OD - you want the 12mm caps. Somewhere here someone replaced them with B6 Bleeder caps IIRC.
08-17-2022, 06:12 AM | #7 |
Not sure of the size, but I installed these on two of my Gatekeeper kit shocks on my recent builds. |
08-17-2022, 06:12 AM | #8 |
Thank you for a useful response that doesnt include quotes on how to use search engines on the internet. I appreciate the wealth of knowledge of those in this group.
08-17-2022, 06:15 AM | #9 |
08-17-2022, 06:19 AM | #10 |
Gatekeeper Builders Kit Shock Caps - Similar Threads | ||||
Trail Truck vs Gatekeeper Builders Kit | HailBoognish | Element RC 1/10 Enduro Trail Truck Sendero | 0 | 11-03-2021 10:04 AM |
Which SCX10 ii? Raw Builders Kit, Cherokee Kit or RTR | Clarkbre | Axial SCX10 II | 30 | 03-27-2020 11:25 AM |
Aftermarket shock caps & collars compatible with Axial shock bodies? | Jim85IROC | Axial RR10 Bomber | 5 | 08-31-2017 07:53 AM |
Axial Yeti RTR vs KIT shock caps? | BobTeagle | Axial Yeti XL | 3 | 02-18-2015 08:37 PM |
