11-23-2012, 08:29 PM | #1 |
Quarry Creeper Join Date: Dec 2004 Location: Gardnerville
| Glow's new rig - Need some advice....
Long time shafty guy, recently went to a MOA with a an XR10. Got tired of throwing money at those POS axles and finally gave up and scored some Berg axles. Specs: BJ4 Carbon Fiber Chassis Tekin FXR Punk Dig JR Radio Cheapy 35t motors, soon to be some Holmes 35t Vanquish Wheels with cut/siped rovers Probably some other stuff i'm forgeting. Here's a couple of pics mid rebuild/rewire Here is my question, problem I bought these axles off another board member. They are pretty well built but used. The rear went together perfectly. The front, I ran into an issues with the motor mounting. Seems that one of the motor mount holes is broken/removed. No idea why someone would remove it but this is what i'm dealing with...... Is this motor plate/housing hosed? I can't get the motor to mount or stay in place at all. I've tried larger washers on the motor bolt, even tried a small plate of aluminum that I cut and drilled and a longer bolt into the motor. No matter what I do, I can't get the motor to stay put. gggrrrrr Any suggestions we would be awesome. |
11-23-2012, 08:42 PM | #2 |
| Re: Glow's new rig - Need some advice....
The two separate holes are the motor mounting holes. The original holes were removed in order to mount the servo behind the axle. You'd find this same or very similar mod on 90% or more of used berg axles. Depending on the pinion size you choose to go with you might have to enlarge or tweak the existing holes to have them line up and give you the proper gear mesh. |
11-23-2012, 08:45 PM | #3 |
Interesting.....I figured it was removed for a reason especially after looking at the pics. Ill have to mess with the other holes some more and see what I can do to get it to line up. Thanks man! They obviously got here right on time and exactly what I was looking for. Stay tuned for build # where I put that chassis to use too. |
11-23-2012, 08:54 PM | #4 |
What he said. That actually looks pretty good. I have seen some pretty serious hack jobs before.
11-23-2012, 09:17 PM | #5 |
Thanks guys. That did the trick. I had to adjust the holes but it worked perfectly.
11-28-2012, 05:17 AM | #6 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
I had to do the same to my cases when I went with the D_Lux Delrin axle tubes and Harvo done a pretty dang good job on doing it . And I even had to go with a metric pinion gear
11-28-2012, 09:04 AM | #7 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
Welcome to Bergville. Half the fun is resolving those X factors. Enjoy. J |
01-07-2013, 09:32 AM | #8 |
If the snow won't let up, i'm going to have to waterproof everything. hahaha Only update i've done recently is, Brood motors in mine. Replaced the Integy motors. I can't believe I didn't get a good set of motors sooner. Wow what a difference. |
01-14-2013, 09:27 PM | #9 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
yup looks like an sounds like money here
03-02-2013, 05:46 PM | #10 |
Well it didn't take long for some carnage. And I can't find crap to replace it. ARGH |
03-02-2013, 06:00 PM | #11 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Re: Glow's new rig - Need some advice.... sheesh! I would start looking at SDS small gears! |
03-02-2013, 06:07 PM | #12 |
| Re: Glow's new rig - Need some advice.... |
Glow's new rig - Need some advice.... - Similar Threads | ||||
1:1 Rig Advice | LR3 | Chit Chat | 33 | 12-16-2010 08:46 PM |
Noob rig. Need lots of advice. | sim | Newbie General | 15 | 08-08-2009 01:41 AM |
Thinking about building a 2.2 rig - advice? | Indy | Minnesota | 8 | 04-05-2008 11:40 AM |
scale rig advice | KYScorpion | Newbie General | 3 | 04-04-2008 07:21 PM |
