03-11-2013, 10:09 AM | #61 |
| Re: **NEW** DLUX gearboxes and tubes
And the all important question.....what's the weight?!? Well, I can't answer that directly, but I did hear Erik telling one competitor all weekend who was driving an XR that he could help him lose 2oz out of his rear end..... |
03-11-2013, 10:25 AM | #62 | |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| Re: **NEW** DLUX gearboxes and tubes Quote:
Edit: It's on the first page. 4.5oz. That's complete! Last edited by stubs179; 03-11-2013 at 10:28 AM. | |
03-11-2013, 10:29 AM | #63 |
Ahh....OK. I didnt reread the thread, just the new posts...
03-11-2013, 03:43 PM | #64 | |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Carbon Fiber might crack the resin, but it doesn't separate if you use good quality CF materials. Lets not even discuss the hardness or tensile strengths of the 2 materials. | |
03-11-2013, 07:08 PM | #65 |
Rock Crawler Join Date: Oct 2010 Location: NW Washington
Nice work Erik, they look amazing. They look like they have alot of drive time on them. Cant wait to see some detailed pics.
03-11-2013, 10:26 PM | #66 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
| Re: **NEW** DLUX gearboxes and tubes Yeah, I know the tensile strength of the shit. Do you know what humidity dose to it. Let alone, what it will do to an exposed bearing seat? Just thoughts, you got take that into factors in the long run. I just think some guy here should test them. A guy at my work is a carbon fiber freak and knows the does and don't of the fiber. I'll pick his brain on the subject tomorrow.
03-12-2013, 03:19 AM | #67 |
&075 would be a better alternative to delrin in this situation.
03-12-2013, 07:22 AM | #68 |
| Re: **NEW** DLUX gearboxes and tubes Right on, don't get me wrong guys. I love the gear cases, just concerned about fiber separation at the exposed bearing seat in humid conditions. I know you can't just slap CA on it and call it a day. That would F@$k your tolerance of the bearing seat up. Not being a dick here. Just throwing some ideas around.
03-12-2013, 07:36 AM | #69 | |
03-12-2013, 07:47 AM | #70 |
Erik is a smart dude, he won't put out any junk. |
03-12-2013, 10:23 AM | #71 | |||||
If you look at the front mount, I cut the bottom part of the upper link mount off so that way its ultra easy to adjust clocking and there is plenty of room for putting the servo wherever you want. Also on the front, the 3 pieces need 2 extra screws so they are secure. Edit: fixed to reflect correct spacing. Say you wanted to space the upper link mounts .250 in the middle. You would then take one of the CF pieces, move it next to the opposite CF piece, put in your .250 spacer and youre good to go. On the rear, you (or I if there is enough demand), would need to cut the bottom off so it resembles the front, throw in the 2 extra screws/nuts and do the same. Thats the quick and confusing version. I will go over this in detail later if its something more people want to mess with. Bottom line is that it will be easy and still extremely functional to put your links where ever you want. Just for more conversation.... talking to some XR guys (and with the current fad of wanting less axle separation) these axles could allow you to literally place the upper link mounts at the same vertical plane as the lowers in the rear and ultra low in the front so, these axles are extremely flex-able as far as upper link placement goes. Possible to have more separation that a Bully and less separation than a XR all in the same package. I can also go over this in detail if there is interest. Quote:
Yeah, its going to be 2.5 maybe 3oz if I am lucky over a HEAVILY modified XR rear axle. We never did come to a conclusion of what an extreme light weight front weighs. It will be much more savings over an average XR axle. Posting pics in the first couple of posts now.... Thanks for the good words Ted. Last edited by Erik D_lux; 03-12-2013 at 05:16 PM. | |||||
03-12-2013, 10:32 AM | #72 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
Hey Erik I'm from Michigan and have never had a problem with cf from the climate. Only problem I have had was a cracked wheel face or two from a extreme fall. Later, Farmer |
03-12-2013, 10:37 AM | #73 |
Quarry Creeper Join Date: Feb 2011 Location: Fenton, Mi
I'm from Michigan and haven't had a problem with my cf wheels or chassis... Just took ca glue around the edge of the part that takes the grunt of falls and haven't had an issue.... Good job on the cases bud, top notch as usual!!!
03-12-2013, 10:41 AM | #74 |
| Re: **NEW** DLUX gearboxes and tubes |
03-12-2013, 10:41 AM | #75 |
Thanks guys! I have dealt with a bit of CF and never had a problem. I actually think that people are used to horrible quality CF if they have fraying or splitting. I also believe that the moisture is a myth and my supplier agrees. I literally soak my CF wheels in soapy water when I clean them up and to my knowledge I still have zero failures with my wheels. Anyway, if we could keep the discussion on topic I would appreciate it. If we want to do CF tech I think it would be a great topic in the General section. |
03-12-2013, 10:44 AM | #76 |
Quarry Creeper Join Date: Nov 2008 Location: UK
I'd put a strip of teflon sheet under to protect plus it will help it slide across the rocks easier.. I do that now anyway. |
03-12-2013, 11:00 AM | #77 |
Thank for extinguishing the urbinlegend of carbonfiber failure.
03-12-2013, 11:04 AM | #78 |
Quarry Creeper Join Date: Dec 2004 Location: Gardnerville
So now on the the important stuff...........................When can I place an order???? hahahahaha
03-12-2013, 12:02 PM | #79 | ||
| Re: **NEW** DLUX gearboxes and tubes GOBS OF PICTURES AND INFO ADDED TO POST #2 Quote:
This has already been a huge project. I am still a 1 man show and I am overwhelmed with what I already have going one. Having said that, I will need people to be really patient with me. At this point I dont even know my time put into each set, its a lot though. I am no slacker and I will work as hard as possible to get these out in a timely fashion. | ||
03-12-2013, 12:11 PM | #80 |
Nice pics those look very interesting, looking forward to seeing some builds using them. |
**NEW** DLUX gearboxes and tubes - Similar Threads | ||||
xr10 gearboxes | iceman320 | Axial XR10 | 31 | 04-11-2013 07:55 PM |
is more gearboxes actually more reduction??? | thecrusader | Newbie General | 2 | 03-09-2013 10:02 PM |
Dlux Delrin Axle Tubes | jdacus | EnRoute Berg | 11 | 11-15-2012 08:08 AM |
gearboxes | silver | General Crawlers | 4 | 12-05-2005 08:36 PM |
