03-09-2014, 09:15 PM | #1 |
Quarry Creeper Join Date: Nov 2013 Location: Pittsburgh
| Berg Pinion Gear
What is the pitch of the pinion gear for berg axle? What tooth count is everyone running?
03-09-2014, 09:33 PM | #2 |
| Re: Berg Pinion Gear
Pretty much your only option will be a RRP1112 for 12t, RRP1113 for 13t etc,. You will want 12t for your axles, for sure.
03-10-2014, 05:18 AM | #3 |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
48 mod .6 I believe.
03-10-2014, 05:46 AM | #4 |
Newbie Join Date: Sep 2013 Location: italy
berg form 0.6 ....... Engine 45 T = 16-tooth engine results 30-35 T Engine 35 T = 14-tooth engine results 40-45 T Engine 55 T = 12-13 teeth-engine results 60-70 T or motor 40 T = 15-16 = 27-30 T stubby result berg for Last edited by THX_138; 08-19-2014 at 06:06 AM. |
03-10-2014, 12:01 PM | #5 |
Since going dual ESC I've always run 14t pinions in my berg V1 axles. The part number would be RRP1114...like Erik said you just change out the last two numbers in the part number for whatever tooth count you want. The pinions are a METRIC 48P. Most rigs like the SCX10, AX10, XR10, and others are all STANDARD 48P so be sure you're getting the right part! I am 99.9% sure you will not find these in a local store. |
Berg Pinion Gear - Similar Threads | ||||
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
Berg tracer pinion gear??? Confused!!! | vti-chris | EnRoute Berg | 6 | 06-14-2011 04:20 PM |
