05-03-2015, 02:39 PM | #121 |
| Re: Hittman's Dlux Berg Build |
05-03-2015, 02:49 PM | #122 |
Ok, so let's get this thread caught up. So I changed from the double agent to the Sudu pro chassis. I was able to use my existing links which was cool. The Sudu is more of a 60/40 setup classis, but the links I had were 50/50. This just meant my shock location was a little different than intended, but I am still very happy with how it turned out. The chassis feels great. With the new chassis I put some new shock oil in. 45wt in the rear and 40wt up front. I brought the spring collars all the way up to where there was no preload on the spring, but they were just sitting on the top. Suspension feels great now. Feels like the shocks are doing the work, not the springs. So let's recap, First comp/ first run with the Sudu pro. Went extremely well. Courses were very tough all day. During the change I also went to super narrow voodoos in the rear. They felt great. Made squeezing through gates that much easier. Here was the video from the comp. Its a combo of my sporty, super, and pro runs.. Thanks ChrisB https://youtu.be/X0YBoePf0lk And here were the scores again: Pics from the comp will be coming soon. |
05-03-2015, 03:02 PM | #123 |
Here are some pics of the current setup. I have a blue skid.. just need to install it. |
05-03-2015, 04:12 PM | #124 |
Quarry Creeper Join Date: Feb 2015 Location: Australia
Your rig looks fantastic Hitman, love the paint theme. |
05-03-2015, 05:20 PM | #125 |
RCC Addict Join Date: May 2012 Location: Folsom
Im pretty sure the Double agent was designed to be a 40/60 chassis too.
05-03-2015, 08:52 PM | #126 |
| Re: Hittman's Dlux Berg Build Thank you. Yes, I believe so as well. But with the adjustable shock arms it has, it can be run either way. |
05-04-2015, 05:30 AM | #127 |
Yay, video!!!! Great job brutha! Keep up that crawling and we might just get to actual meet this year, at World's! :cool: |
05-04-2015, 07:11 AM | #128 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodø city
05-08-2015, 09:21 AM | #129 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
H, What is the name of your org and where do you post season scores and attendance? Cheers, J |
05-08-2015, 10:16 AM | #130 | |
| Re: Hittman's Dlux Berg Build Quote:
We have a stickied thread in the New Mexico section. Currently we do not have the individual comp scores or season totals posted. We have two more comps, then I will be running all the numbers. Should be 3-4 weeks and I will have all those numbers figured out. | |
05-08-2015, 10:54 AM | #131 | |
Are any of NMRCC attending the AZ shootout? Cheers, J | |
05-08-2015, 11:36 AM | #132 | |
7 pro (up to 10) 8 spo (up to 11) 4 super 10 1.9 trail (up to 25) 10 2.2 trail (up to 15) I think maybe 10 of us will be attending the shootout this year | |
05-08-2015, 01:06 PM | #133 |
H, Please post up in the Shootout thread who's attending by class if they have not already...or feel free to respond here and I'll update the list for KJ. Cheers, J |
05-25-2015, 02:38 PM | #134 |
Here were the pics from our last comp. And then my little bit of popping.. Turned into a lot of popping. Field repairs!! And that's about where my day ended. I started the last courses so I didn't get a +50.. By far my worst comp ever. But Owell, it is fixed now, and I a, ready to rock for AZ. We had our season closer this past weekend.. When those pics surface I will post them. Here were the disastrous scores.. |
05-25-2015, 02:39 PM | #135 |
05-25-2015, 03:15 PM | #136 |
What was the cause of your popping?
05-25-2015, 03:41 PM | #137 |
The milled out area for the second gear on the motor side plate had worn. When I would go forward it disengaged it from the other gears. Dlux's new plates feature an aluminum bearing holder attached to the plate. Everything is all smooth now. |
05-25-2015, 03:48 PM | #138 |
I was always worried about that tiny little ridge holding in that bearing. I pretty sure I tried CA gluing that bearing in place, or a least give a little extra to hold him still. I have a new set of those plates which I need to install! thanks for the motivation! How'd the gears hold up to the abuse? |
05-25-2015, 03:56 PM | #139 | |
05-26-2015, 12:01 PM | #140 |
RCC Addict Join Date: Jun 2007 Location: Finland
Shit happens sometimes. I too hate when it's all in one comp. Good luck for you to AZ! |
Hittman's Dlux Berg Build - Similar Threads | ||||
Dlux Berg Build | Erik D_lux | EnRoute Berg | 1696 | 05-22-2018 10:10 PM |
Hittman's SMASH Build | Hittman | Axial XR10 | 994 | 02-28-2015 09:21 AM |
Sessions YTC Dlux berg build | Session | EnRoute Berg | 126 | 07-03-2014 11:27 PM |
dnsinoz Berg/Dlux Zero build | dnsinoz | EnRoute Berg | 0 | 03-09-2013 08:48 AM |
