05-16-2016, 06:38 PM | #21 | |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: Sic's 1st Berg has a Bounty! Quote:
The car Im not really worried about its the driver gettin a lil better & learning err day tho! | |
05-19-2016, 06:29 AM | #22 |
I'm not used to a build draaaaaaging along like this. Other things need attention other than electronics so looks like shocks are next(which i hate the most). Traxxas 3.5" lathed,cap mod,Dlux cups & miniT springs MIP bypass pistons(#12133) Sooooooo if anyone has any input on this setup PLEASE fire away! I read where mip allows how to install them but just want to check with the current users http://www.google.com/url?sa=t&sourc...2_LocyqRIYDKfg Still got more "Dluxness" coming.... Last edited by sic1to; 05-19-2016 at 06:47 AM. |
05-19-2016, 08:26 AM | #23 |
Man, if you hate shocks, hold on to your hat! Things are about to get bumpy! I think I had a good solid 8hr of drive time before I figured out what I liked on the bypass pistons? What I figured out and what I like: I like my front to extend fast and compress slow I like my front to extend slow and compress fast To do this, you will need to install the pistons opposite of each other. I just looked at my left over shims. Looks like they are all tan/white and if I remember right, blue sounds like what I used at all 4 corners. The shims basically set the difference between rebound and compression. If you do a thicker shim, it gets more extreme, thinner shim makes so there is less difference between the two. So, you only want to mess with the shims to get the difference of the compression/extension feel. After you nail that down, all you have to do is change the shock oil to your liking. My taste in shock oil didnt change from the MIP setup to non. I use 45wt oil in the summer, 30 or 35 in the winter. I never change the shims since I found the ratio that I like. |
05-19-2016, 10:07 AM | #24 | |
05-19-2016, 02:46 PM | #25 |
I've got a STUBBY! Join Date: Apr 2011 Location: Newcastle Australia
Can someone confirm the part# of the mip Pistons? Thanks Josh Sent from my iPhone using Tapatalk |
05-19-2016, 05:15 PM | #26 |
| Re: Sic's 1st Berg has a Bounty! |
06-19-2016, 10:55 AM | #27 |
The wait is over! I decided to break down XR after ECC to get this berg goin. I am soooooooooooooooo impressed with this Bounty Hunter The truck feels different of course but the way it pulls lines is really smooth & very stable So i skipped the bb's & used the egressor shocks(already built) 13t pullers,br mini's,7950 I stripped a servo horn at 1st comp but 7950 is still ok! Ty DLUX! Now i gotta drive....drive....drive...& drive some more |
06-20-2016, 07:21 PM | #28 |
Sooooo.... it's looking pretty good. Erik is one of the best builders in the country, but he and I never agree much on 2 things. Knuckle weight and Shock setup LOL I think it's an our rocks vs their rocks thing, where ours have more holes and theirs are more big-one-piece rocks. Anyway... since you are trying things out with this chassis and setup (and MIPs) I'd suggest much lighter weight shock oil with the BBs. I likes 5wt. most of the time. They are slow shocks anyway. Incredibly smooth, but slower than others. Also, try your loaded dice with no slugs. Then only 3 or 4 slugs toward the front. It will help carry the front wheel over the occasional hole instead of flipping the truck over into it. ALOT of weight is good for ledge climbing... etc. but I have a hard time with it on everything else out here. Put a little more support in the foam up front too. That lower weight in the wheels really pushes hard on the sidewall in downhill hard turns. Just sayin' |
06-20-2016, 07:51 PM | #29 |
"GOD SPEED" Join Date: Oct 2014 Location: Wouldn't you like to know
Trucks looking good, you will not be disappointed with the switch, I will tell you it definitely takes some getting use to, I have changed my setup a lot since ECC all for the better, need to get it dialed in before NENC. "GOD SPEED" |
06-20-2016, 09:14 PM | #30 | |
[QUOTE=nerby149;5522166]Trucks looking good, you will not be disappointed with the switch, I will tell you it definitely takes some getting use to, I have changed my setup a lot since ECC all for the better, need to get it dialed in before NENC. Ty bro! Its already pullin lines i never could b4 & took 1st place this weekend. With that being first time on the rocks...i was like | |
06-21-2016, 09:37 AM | #31 | |
I think if everybody could crawl on the same rocks that we could all come to somewhat the same conclusion. I think the rocks are different but then again, so is the person. Even if you dont throw a ton of weight in those loaded dice, what little you do put in them is super beneficial. | |
06-21-2016, 01:14 PM | #32 | |
06-21-2016, 02:25 PM | #33 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
Glad you made the switch! I'm hooked on my DLUX superlites! It was fun comping with you again! |
06-21-2016, 05:15 PM | #34 | |
Yeah it was a blast to hang out again! Was you gonna be able to come join us at any of the other evwnts comin up? | |
06-21-2016, 05:18 PM | #35 |
06-21-2016, 05:19 PM | #36 |
Awesome!
07-03-2016, 12:39 PM | #37 |
Got a few updates...First this truck is amazing to me because it surprises me every time its on the rocks! Ok on to the lil updates i have goin on! I used panels provided with a lil paint on em Skin templates for new Krawler Koncept skins! Also got the lower sides mocked up to have done too The next update is the Krazed Builds elec tray! I had to remove approx.025" of total length to clear 7075 skid that was not gettin the grinding. Perfect Still gotta replace the short servo horn im usinh til others come in! Omg I almost forgot I UPGRADED to a Airtronics MT-4 after using one at ecc for like 45sec!!!!!!!!!!!!!+ TY Troy |
07-03-2016, 01:18 PM | #38 |
Rock Crawler Join Date: Dec 2010 Location: Ct.
Bounty Hunter is looking great! Can't wait to see what Krawler Konceptz comes up with for skins. I switched to the Mt4 in the middle of last season and don't know how I ever lived without it!! The lever for dig functions works awesome!!
07-03-2016, 02:01 PM | #39 |
Thanx Butch! Yeah its one of those things where words cant quite explain the lever feature vs using it! With all the skins out there it was hard "to be different" but i think Michelle(ty btw) has my skins just about ready to look at so we see soon.....
07-03-2016, 02:05 PM | #40 |
Rock Crawler Join Date: Nov 2011 Location: Asheville
Subbed. It's going down this sat. Can't wait. See ya there. Oh BTW if you like the lever the 3d joystick mod is even better IMO Sent from my SM-G900V using Tapatalk |
Sic's 1st Berg has a Bounty! - Similar Threads | ||||
Sic's sporty... | sic1to | Axial AX-10 Scorpion | 103 | 06-28-2017 10:56 PM |
sic's g6 | sic1to | Axial SCX-10 | 33 | 12-11-2016 07:53 PM |
Joshie builds a berg "Bounty Hunter Style" | Joshie | EnRoute Berg | 16 | 05-17-2016 12:36 PM |
Bounty lines | Erik D_lux | DLUX presents the Red Rock Rumble | 6 | 04-21-2015 07:46 AM |
project: BOUNTY HUNTER | buggy | 2.2 Scale Rigs | 41 | 05-07-2012 04:44 PM |
