02-09-2018, 01:02 AM | #1 |
Rock Stacker Join Date: Mar 2013 Location: ENGLAND
| ssd pro scx10 c-hubs with berg knuckles
ive got a set of berg axles with VP knuckles and super 300's. im wanting to make tubes so need to run a scx10/ax10 c-hub. will the ssd pro scx10 c-hubs work? i can t see anything about them being 8degree ( i need 0) https://www.tcscrawlers.com/SSD-Alum...sd00068-72.htm axial are ideal but they are silly money in the uk (~$50) thanks in advance |
02-11-2018, 09:17 PM | #2 |
RCC Addict Join Date: Mar 2009 Location: The REAL Nor-Cal
| Re: ssd pro scx10 c-hubs with berg knuckles
Yes, those are the 0°. I just used them on my Berg with DLux knuckles. |
02-11-2018, 11:34 PM | #3 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
| Re: ssd pro scx10 c-hubs with berg knuckles |
02-12-2018, 02:27 AM | #4 |
Rock Crawler Join Date: May 2012 Location: Australia
I also use them on my rigs. I actually prefer that they have more material within them then the axial ones. The axial ones only have the 4 little nipples, I found the SSD hold much better on the tubes. |
02-12-2018, 09:49 AM | #5 |
02-16-2018, 01:11 PM | #6 |
Rock Crawler Join Date: May 2009 Location: Calgary
02-16-2018, 02:00 PM | #7 |
02-16-2018, 06:06 PM | #8 | |
| Re: ssd pro scx10 c-hubs with berg knuckles Quote:
Why SSD? Because they are a better looking part to me than the Axial ones. They look to have more material where I have seen the Axial part fail in the past. I also do not need the extra hole for caster adjustment since my tubes can be rotated infinitely at the gearbox. I also don't like the Axial logo plastered on my pretty MOA. It ain't no XR10! Why 0°? My driving has not been as good since I went to 8° a few years ago. I have had a couple times when I could actually sit and watch my car do something I wasn't expecting it to do and I attribute it to the angle of the stub shaft either loading or unloading the balance of the car, and I think 0° may make it more neutral. Who knows if it will help or not, but worth trying. Why Dlux? With these knuckles I can use more weight. Again, I want more weight to make my car more neutral and less twitchy. Not only that, but they seem to be strong as hell and are the only ones I know of that I can switch c- hubs between 0° and 8° if I want to and keep all the same parts! | |
02-24-2018, 06:20 AM | #9 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
This thread is amusing, please poke the bear again.
02-24-2018, 09:05 AM | #10 |
02-25-2018, 10:14 AM | #11 |
02-26-2018, 10:19 AM | #12 |
03-05-2018, 09:20 AM | #13 |
The whole reason 8* was invented was for on road manners and getting a car to turn at higher speeds properly. If youre head is not in your ass, you would know that is completely different than slow, off road crawling. You would have to be an old ignorant douche bag to think that 8* was designed around rock crawling performance. To my knowledge, its never even been tried in the real world. But,... since I guess a car or F150 runs 8*, that must mean an off road only car needs it too? I love Sloskis argument towards it too.. "its proper". Good tech slowski, good tech. |
03-06-2018, 02:25 AM | #14 |
RCC Addict Join Date: Oct 2014 Location: UK
That's interesting. Why has the RC crawling world gone 8* KPI then, because the Wraith came out with it? (This is a serious question) I can understand scale trucks having 8* KPI as they are copying 1:1 none crawler axles. But going by what is used in 1:1 crawling (as stated above), zero degree should be an optional upgrade for RC crawlers built from scale trucks. |
03-06-2018, 03:19 AM | #15 | |
03-06-2018, 04:22 AM | #16 |
03-06-2018, 05:15 AM | #17 | |
The AR60 splined C hubs on those axles are design for SCX10 CVD spec so dont fit AR60 CVDs. The reason for putting Ar60 splines on those axles was at the time people were doing XR mod using AR60 C hubs/knuckles. So it was easy to do on those axles. The C hubs were only made so they were still compatible with stock SCX10 knuckles/cvds. So those C hubs are not correct spec anyway. Last edited by SSD; 03-06-2018 at 05:17 AM. | |
03-06-2018, 05:15 AM | #18 |
03-06-2018, 06:01 AM | #19 | |
Not true using your (and other "normal" knuckle manufacturers) parts, you're correct. But the people that have contacted you about the c hubs all use knuckles made by dluxfab.com. They can be used with a multitude of different c hubs as well as switch between 0* scx10 and 8* ar60 easily. So yea, your c hubs are exactly what we need but none of us are going to buy the quantity you wish to move atbthe price you are after per pair. These are for a comp crawling market which is a smaller niche, you'd move them if they were available. | |
03-06-2018, 09:22 AM | #20 |
| Re: ssd pro scx10 c-hubs with berg knuckles If DLux who make the knuckles they fit is not confident in selling them then I have no reason to believe SSD could sell enough of them. They are too niche. I'm not going to make a batch to sell only 20 sets and be stuck with the rest of them and make a loss.
ssd pro scx10 c-hubs with berg knuckles - Similar Threads | ||||
New SSD SCX10 II Knuckles/C Hubs | SSD | Axial SCX10 II | 142 | 06-05-2017 02:16 AM |
New SSD Pro Knuckles & C Hubs for Ascender | SSD | Vaterra Ascender | 30 | 02-24-2017 02:53 AM |
New SSD CVDs, Pro Knuckles & C hubs for Wraith | SSD | Axial Wraith | 3 | 04-14-2016 08:45 PM |
New SSD CVDs, Pro Knuckles & C Hubs for RR10 | SSD | Axial RR10 Bomber | 6 | 03-28-2016 02:34 PM |
SSD pro knuckles for SCX10 axles | joe.bielski | Axial AX-10 Scorpion | 5 | 10-20-2015 07:50 PM |
