12-11-2012, 04:19 PM | #141 |
| Re: DmG's - MASTER BLASTER
Looks awsome man! I love that exo trans in there! I am been wanting to do something similar.. Now this gives me the motivation to |
01-30-2013, 01:03 PM | #142 |
RCC Addict Join Date: Aug 2011 Location: Pipersville
Any updates on this one. Wanting to see some video......... |
01-30-2013, 02:39 PM | #143 |
Damn Jerry you are probably one of the best if not THE BEST chassis builder I've ever seen on RCC. You sure have the technical and aesthetic sides covered in your siiiick builds. I'm still digging my Lucifer 2.2 KOH tuber you built me....12,000+ views on that thread already. Plus I just put on Wraith axles and some SSZ's looking super clean! Check out my updates in my sig below!
01-30-2013, 02:49 PM | #144 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
If I ever win the lottery, you sir would be charged with the task of building my chassis. You are truly an artist, the care & attention to detail is amazing. Keep up the great work (making me drool & covet things I likely will not get.) |
01-30-2013, 07:24 PM | #145 |
Rock Crawler Join Date: Jan 2010 Location: In the lair editing video
I managed to get a few shots of it before Jerry shelled the gears in it. http://youtu.be/at8ZZxyQCrc Sent from my iPad using Tapatalk |
01-31-2013, 05:51 AM | #146 |
Rock Crawler Join Date: Feb 2006 Location: sunny acres
Nice. Looks like it scared the bejesus out one dude. Saw him backing away and hiding behind a tree. |
01-31-2013, 06:13 PM | #147 |
Love it. Make more please. Lol
02-01-2013, 06:21 AM | #148 |
yes love it, its just sick
04-17-2014, 03:35 PM | #149 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
And then...? Seriously Jerry, this is a bad ass rig. I searched it out because I'm finding I need more wheel speed and want to switch to the exo trans. I'm still trying to figure out the drive shafts since I'm putting mine in BWD whiplash. What's the latest with this rig? ...Sent from the car headed home from the RECON G6 in St Louis... |
12-21-2014, 10:19 AM | #150 |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
| Re: DmG's - MASTER BLASTER up-date ! MASTER BLASTER 2.0 yes still around - together & running. new up-dates the DmG's formula off. been working hard on getting more speed out of the MB, and now have finely found the combination that seems to be working real well. first changed over the ESC from a mamba max pro to a Tekin T8 ESC. this a-lone made a HUGE difference replaced the homemade center locker with a Blue Monkey Yeti front locker. the BM locker went right in the Vanquish EXO motor/trans mount - no mods need ! changed the motor from a 3000kv Novak 550 to a 4000kv Novak 550, may be running a Tekin HD Pro4 550 motor next. went from 3 & 4 cell running - to a high discharge (130c & above) 2 cell packs ! 13/54 gearing on 2 cell, more than fast enough & no heat problems what so ever ! around 120 degrees in temps this motor/battery with the new ESC has now turned it to a almost un-drivable BEAST !! changed the front ring & pinion to a "over drive" gear set - to help with keeping it in a straight line put some old MOAB pro-lines on it so i could run it more on mutable surfaces to do testing - now i need to try to balance the foam/tire some ! with the wheel speed its now running anything out of balance shows up - bad ! over all, the new changes have made HUGE difference & its now where its crazy/fun to drive ! more KV on the motor - less battery = lower temps & weight = more fun ! were working a Video so everyone can see the power of the MASTER BLASTER thx for looking & more to come !! Last edited by the DMG; 03-27-2015 at 07:26 PM. |
