08-18-2012, 06:31 PM | #1 |
Pebble Pounder Join Date: Nov 2009 Location: Monterey Bay, CA
| SCX10 to FOFF how?
what does it take to make my SCX10 to do the duties of FOFF? I understand a lowered stance and sand claws of some sort. but what else? how do I come about lowering my ride?
08-18-2012, 06:37 PM | #2 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
| Re: SCX10 to FOFF how?
spacers in the stock shocks work pretty well. or shorter shocks. throw a brushless systema in it an some paddles. go
08-18-2012, 06:53 PM | #3 |
You'll need to beef up the drivetrain to handle brushless power and speed. Robinson Racing Outdrive gear Robinson Racing Outdrive Diff Lock Gear AX10/SCX10 RR Idler gear Robinson Racing Hard Steel Idler Gear AX10/SCX10 MIP Drive Shafts MIP C-Drive Spline Set for Axial AX10 Scorpion (2) Axial Universal's Axial AX10 Competition Universal Joint Drive Shaft Set (1 Pair) Axial overdrive gears in each axle will gain you more speed Axial HEAVY DUTY BEVEL GEAR SET 36T/14T Axial/VP Knuckles and CHubs Axial Aluminum C Hub Carrier, Black (2) Axial Hi-clearance Knuckles (2pcs) Strong Lockers RCP*Crawlers*Stainless... or http://www.rccrawler.com/forum/axles...ls-locker.html And I highly recommend Beef Tubes to hold your axles together http://www.rccrawler.com/forum/axles...e-updated.html |
08-19-2012, 08:13 AM | #4 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
| Re: SCX10 to FOFF how? |
SCX10 to FOFF how? - Similar Threads | ||||
scx10 or wraith for foff | axialscx10 foff | Formula Offroad | 10 | 07-11-2012 10:00 AM |
Another SCX10 FOFF | pottymouth | Formula Offroad | 14 | 05-08-2012 06:05 PM |
My FOFF with the SCX10 Axial - Need more power ! | Tony Truand | Formula Offroad | 8 | 10-25-2011 05:10 PM |
