03-19-2013, 03:53 PM | #1 |
Pebble Pounder Join Date: Dec 2010 Location: UK
| Gmade shafts alternative fix? (Pic heavy)
Just thought I'd share what I've been up to. Bought some CR01 updated shafts. They're exactly the same diameter as stock Stock CR01 Narrower part of shaft almost identical (close enough anyway) Stock CR01 Cut and filed to the correct length And the flat filed to suit. The finished shafts. Had a few 3s packs with a 35t brushed motor and (so far at least) had no issues at all. Previous to this I'd broken 4 standard shafts. Hope this helps guys, seems a success so far. |
03-22-2013, 08:38 AM | #2 |
Pebble Pounder Join Date: Jun 2009 Location: England
| Re: Gmade shafts alternative fix? (Pic heavy)
Excellent work, I'm sure this will help many people here |
03-22-2013, 12:35 PM | #3 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
Nice work! Have you broken a pin on these yet? I have upgraded mine to XVD's (see signature for link) and have not broken mine. JunFac now has CVA's available for the R1 too. |
03-22-2013, 12:45 PM | #4 |
Up to yet my modded shafts seem to be holding up fine. I found out about Junfacs cvd's after I'd started doing this. After seeing that a couple of people had broken the junfac cvd's I thought I'd share. A mate of mine has been running a CR01 for many years and never broken a standard shaft so, these uprated shafts should do the trick. |
03-26-2013, 05:37 PM | #5 |
Rock Stacker Join Date: Feb 2013 Location: North Texas
i ordered the CVA's from Junfac for my 4WS, if they dont cut it then i will definitley look into this. thanks for the information
05-26-2013, 10:27 PM | #6 |
I've now broken 3 out of the 4 JunFac CVA's. 2 of them wasnt even when I was rock crawling. Just driving in soft dirt and grass. Thats 3 broken axle shafts with only 4 battery packs through my rig. Definitely time to upgrade the upgrades. I would like to let everyone else know about these poor axle shafts and hope to defer you away from them and save your money. Modify some like Syncrog60 (above) or modify some MIP's. there's another thread somewhere on here for doing that. |
05-28-2013, 11:39 AM | #7 |
Pebble Pounder Join Date: Dec 2012 Location: Utah
I findit wierd that all of you are breaking these Junfac axle shafts. I got mine installed when they first released and I haven't broken them yet (knock on wood) and I run mine on 2s lipo with dig and weighted wheels. You guys must be puttting your r1's throught the ringer.
Gmade shafts alternative fix? (Pic heavy) - Similar Threads | ||||
I might as well have one too (pic heavy!) | CAPCbass | Axial Wraith | 23 | 08-16-2013 01:04 AM |
Want to buy a Gmade R1 what do I need to fix? | Rckhrse | G-Made Crawlers | 8 | 02-23-2013 01:26 AM |
my at home course **pic very heavy** | dodgesavageone | Axial SCX-10 | 7 | 08-22-2011 04:52 PM |
Quick fix stock servo mount Alternative needed | CrawlinMike | Losi Mini-Rock Crawler | 6 | 02-21-2009 07:16 PM |
