03-19-2013, 07:45 PM | #1 |
Newbie Join Date: Jan 2013 Location: chico
| r1 drivelines
need to upgrade my drivelines what are your guys suggestions?
03-19-2013, 08:27 PM | #2 |
Rock Crawler Join Date: Jul 2012 Location: Brisbane, Australia
| Re: r1 drivelines
Drive shafts or the transmission? Junfac do really nice carbon steel drive shafts. No one makes steel gears for the transmission yet.
03-22-2013, 10:26 AM | #3 |
Rock Stacker Join Date: Feb 2013 Location: North Texas
| Re: r1 drivelines
what about the ring and pinion? anybody know of different ratios other than stock? the wraith has three sets for different applications, all better gear ratios the what Gmade offers as stock. i would like something a little lower for crawling/trails without having to go crazy with the spur/pinion. the portals gear reduction helps but not much
03-22-2013, 12:42 PM | #4 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
| Re: r1 drivelines
Drive-Shafts?? Don't get the stated JunFac one for the R1, 95-130 just aint cutting it, they are too short if you plan on driving it for any reason. Get the longest ones you can find. If you start messing with the position/location of the axle's it will lengthen your drive-lines and cause jumping/breakage/slippage. I think the 120-155's should work. They were out of stock a while ago so I had to settle for the 102-140. Just got them and need to install so haven't tested. |
03-25-2013, 11:40 PM | #5 |
| Re: r1 drivelines
i ended up getting the integy aluminum drivelines and im happy with them
03-26-2013, 02:16 AM | #6 |
Quarry Creeper Join Date: Mar 2013 Location: Pilipinas
| Re: r1 drivelines
i ordered the JunFac 107-142s..
r1 drivelines - Similar Threads | ||||
Drivelines | meanbgreen | Newbie General | 3 | 08-18-2011 09:45 PM |
drivelines | makahacrawler | Axial AX-10 Scorpion | 9 | 12-21-2008 01:42 PM |
drivelines | donzx12 | Losi Mini-Rock Crawler | 10 | 11-11-2008 11:36 PM |
drivelines | sickfab | HPI Wheely King | 9 | 08-08-2007 08:59 PM |
