Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: slope in portal axles
Old 03-31-2013, 06:22 PM   #1
Default slope in portal axles
is there anything that can get rid of the slop* in the axles? thanks
530_crawler is offline   Reply With Quote
Old 03-31-2013, 06:54 PM   #2
Default Re: slope in portal axles
Originally Posted by 530_crawler View Post
is there anything that can get rid of the slope in the axles? thanks
*Slop*??
MiniMorris is offline   Reply With Quote
Old 04-01-2013, 10:23 AM   #3
Probably talking about the "axial play" in the axle or "gear lash".
I haven't had a chance to open it op the axial to see where the play is occurring. The only adjustment you can do to reduce the play would be the pinion to diff. You can adjust this by adding in shims on the pinion and in effect push the pinion further into the axle to tighten up the gear mesh here. For the rest of the axle, there isn't much more adjustment available. Check for worn parts and bearings.
cytogen is offline   Reply With Quote
Old 04-06-2013, 11:02 AM   #4
i blew out most of the smaller bearings in the front axle
slope in portal axles - Similar Threads
Rc4wd Portal Axles Jersdunz Tamiya TLT Crawlers 7 05-05-2007 09:19 PM
Portal Axles MTUJeeper General Crawlers 18 12-26-2005 12:57 PM
portal axles Magic Tamiya TLT Crawlers 0 12-20-2004 01:16 PM
