01-03-2016, 05:15 PM | #21 |
Quarry Creeper Join Date: Nov 2014 Location: Northwest Arkansas
| Re: Kristmas Kamodo
The body posts are going to be shortened. No idea why Gmade made them that way.
01-03-2016, 09:44 PM | #22 | |
Newbie Join Date: Jan 2016 Location: Canada
| Re: Kristmas Kamodo Quote:
That's what I thought at first but I only use a small screw driver and stopped when i felt enough tension. And the more I look at it they are not just broken around the screw area spokes are broken and plastic is falling apart everywhere. I have contacted Gmade see what they will say about that. I have some plastic Axial rims never had any problems with those. | |
01-03-2016, 09:46 PM | #23 |
| Re: Kristmas Kamodo |
01-08-2016, 04:45 PM | #24 | |
There are tons of magnetic mounts. I was afraid that the body wouldn't stay put in a comp situation. Rub a bit on the side and get the body loose and you'll have to put your hands on the rig. Loss of points. I realize the rare earth magnets are tough but when your pushing on that bumper that's attached to the body, leverage and the spring from the body will knock it loose. It would be great foe a trail truck. | |
01-23-2016, 10:30 PM | #25 |
| Re: Kristmas Kamodo
I decided to just use the supplied body posts and sacrifice the looks for less trouble during trails runs posted a few pics of it on the forums |
01-24-2016, 12:06 PM | #26 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
| Re: Kristmas Kamodo
Gmade does offer adjustable body mounts as an option part, but I haven't found a U.S. vendor that carries them. I forgot to add them to my list when I purchased the other upgrade parts from Junfac.
01-24-2016, 05:37 PM | #27 |
| Re: Kristmas Kamodo
Was out today with the local club. I finally got to see how this thing ran. The over hanging front and rear bumpers are going to be a problem. I'd get hung on the approach and hen the rear scraped on an incline. Some of the guys suggested making new links and stretching the wheelbase. The wheels don't line up perfectly with the wheel wells anyhow. So I'm going to check the rules for class 1 rigs and see what can be done there. I want to put new bumpers on and sliders for sure. I'm still up in the air about the shocks. I used Teflon tape and green slime on assembly and they still leak. At low speeds, while crawling this thing is so smooth. You cannot hear the thing running. |
02-23-2016, 02:33 AM | #28 |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
| Re: Kristmas Kamodo
Looks good! As for the shocks, they are terrible IMO. I have the transitions on my R1 and have come to live with them having no fluid. Someday it will get new shocks.
02-25-2016, 03:23 PM | #29 |
| Re: Kristmas Kamodo
Thanks. Yeah I've had my fill of them. I've been trying to get my Deadbolt finished before comps start then I plan on tearing into this one. Shocks are on the top of the list of upgrades.
03-02-2016, 12:23 PM | #30 |
Quarry Creeper Join Date: Feb 2009 Location: Houston
| Re: Kristmas Kamodo
How well do the Komodo body holes line up with the SCX10 body post locations. Is it a drop on fit (so long as the wheelbase is right)?
03-02-2016, 05:11 PM | #31 |
| Re: Kristmas Kamodo
The body has no holes if it's a new body. You make them with a body reamer or stepped drill.
03-04-2016, 05:05 PM | #32 | |
03-06-2016, 06:47 PM | #33 |
| Re: Kristmas Kamodo
I agree about the bumpers. I've been focused on my other rigs right now but I plan on changing things up in this one soon. Ran a comp with it this past weekend and it actually did great the way it sits. Still not 100% satisfied.
03-06-2016, 06:47 PM | #34 |
| Re: Kristmas Kamodo
Another
03-06-2016, 06:48 PM | #35 |
| Re: Kristmas Kamodo
One more
05-08-2016, 07:01 PM | #36 |
| Re: Kristmas Kamodo
Doing a few upgrades to the Komodo. I've been neglecting this rig due to the wife getting a new 1:1 truck, had to do a bunch of repairs right off the bat. Any way, brass axle weights, aluminum lock outs and the c hub and knuckle upgrades. Throwing on some Gmade sliders until I can get a set of ScalerFab metal sliders made. |
05-08-2016, 07:02 PM | #37 |
| Re: Kristmas Kamodo
Ordering a servo and horn tonight. Getting ready for The RC4WD Scale Truck Challenge in Disney OK. Lights will go on next week. |
05-08-2016, 07:59 PM | #38 |
Rock Crawler Join Date: Dec 2014 Location: In the sticks
| Re: Kristmas Kamodo
I recently bought the Sawback 4LS which is more or less a Komodo, and to me the link geometry is a little on the strange side. Even though the articulation of the axles with the XD Aeration shocks is perfect, the suspension dose not compress at all while running at any speed more than a crawl over the rough stuff. I haven't heard this complaint about the Komodo yet, so I was wondering if it suffers from the same flaw? The angle change of the axles when compressed is all wrong imo. One other thing is the axle swing with a CMS setup. I finally ended up putting the servo back on the axle so I could get a full range of steering. I'll probably drag the 4LS to Disney with me in case some pre or post event playing happens. The thing is very capable and maybe I'm just wining like a spoiled baby If we get the chance, I'd like to compare the two when at Disney.
05-08-2016, 08:07 PM | #39 |
| Re: Kristmas Kamodo
The Zero Ackerman knuckles and steering link really improve the turning radius. They recommend cvd's to go with it. I have the brass tubes up front and have yet to install the rears. The CMS kit was cheap enough so I threw that in as well. Running a small 3S lipo mounted on the slider brackets helped a lot when "getting vertical".
05-08-2016, 09:35 PM | #40 | |
