10-25-2016, 02:20 PM | #1 |
Newbie Join Date: Oct 2016 Location: West Central IL.
| Gmade R1 Battery Size
I'm getting the R1 RTR that needs 7.4 v Battery I need to no the dimensions so I get the right size. Thanks
10-25-2016, 02:55 PM | #2 |
| Re: Gmade R1 Battery Size
Where do you plan on mounting ? Outback, up high or on the axle ? Hang up and Drive |
10-25-2016, 03:13 PM | #3 |
Pebble Pounder Join Date: Sep 2013 Location: Santa Cruz
| Re: Gmade R1 Battery Size This is a great question with a slew of different answers. I'm running 2S 60C 3800-4000 amp shorty hardpack packs, because I have some on hand. They sort of fit in the battery tray, sticking out the back a little. They fit well atop the front axle with the optional Gmade axle mount. Smaller batteries will give you more options.
10-25-2016, 05:03 PM | #4 |
At first in back then over front axle with LCG kit. Thanks I will get a couple shorty's. Crawl ON
10-25-2016, 05:57 PM | #5 |
I'm running 3s 1300mah on the axle, about 50c, they last 30 minutes each, I use Scotch extreme fasteners with an o ring. On my comp crawler I'm running smaller Brood 850 mah 35c 3S, get about 20 min each I don't want all the weight up top on mine, so I never ran anything larger in size Hang up and Drive Last edited by mikemcE; 10-25-2016 at 06:04 PM. |
10-25-2016, 06:51 PM | #6 | |
| Re: Gmade R1 Battery Size Quote:
10-25-2016, 07:19 PM | #7 |
I was happy with my broods, as I don't comp yet run time is practice. And I can run 3 batt Back to back, no heat issues, just parts failures, but all 4 cvds are gone now Hang up and Drive |
Gmade R1 Battery Size - Similar Threads | ||||
Forward Battery Conversion Battery Size | jimmiejump | Axial Wraith | 2 | 04-13-2016 08:07 AM |
battery size | davosfam | Newbie General | 5 | 07-07-2010 07:22 PM |
Battery Size | Alan | Team Losi Comp Crawler | 7 | 01-03-2010 07:57 PM |
which battery size? | pontiacfreak | Electronics | 2 | 12-16-2009 12:23 PM |
Battery size... | BigJay | Electronics | 2 | 07-24-2005 05:25 AM |
