Thread: Forward Battery Conversion Battery Size
Old 04-13-2016, 06:03 AM   #1
Default Forward Battery Conversion Battery Size
Gathering info on the Wraith Spawn for my next build. I would like to run a 3c lipo. My question is with the Werty WN-08 aluminum front battery plate installed what are the max allowable battery dimensions? Thanks in advance.
jimmiejump is offline   Reply With Quote
Old 04-13-2016, 07:03 AM   #2
Default Re: Forward Battery Conversion Battery Size
I have the same plate in my wraith and I run a 4S battery that measures out to 47mm tall ; 140mm wide ; 26mm deep with no issues. I wouldn't go any taller than 47mm (1.85") as it will hit the hood. You could go up to about 30mm (1.18") deep, if you're electronics box will let you. And maybe another 12mm (.5") on your width if you needed.
Hope this helps!
NWHavok is offline   Reply With Quote
Old 04-13-2016, 08:07 AM   #3
The turnigy 5000 3s just bearly squeezes in mine. I don't think you'd need anything bigger(lasts like 3hrs...). There's plenty of room for most 4000's.
oldpunk is offline   Reply With Quote
Forward Battery Conversion Battery Size - Similar Threads
battery size for forward mod 123nanez Axial Wraith 5 01-22-2015 05:19 AM
battery forward kit tnt-salvage Axial Wraith 5 06-23-2013 06:59 PM
Battery Forward Options? Double D Axial Wraith 10 09-25-2011 05:55 PM
Getting the battery forward. Mic EnRoute Berg 4 06-13-2008 02:24 AM
