Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: Soze's GMADE GOM GR01 Build
Old 11-10-2017, 03:04 PM   #21
Default Re: Soze's GMADE GOM GR01 Build
Originally Posted by soze View Post
I've succumbed to ordering from JunFac. Will take pictures of the new parts when they come in.
"succumbed"? Is Junfac not a good place to order from? (Asking to learn)
Roach374 is offline   Reply With Quote
Old 11-10-2017, 03:07 PM   #22
Nah it's fine. Just higher shipping costs since it's shipping from Korea.
If I waited for RPP or any other vendor around here, there's the potential to use coupon codes + lower shipping cost.
soze is offline   Reply With Quote
Old 11-10-2017, 08:11 PM   #23
Is your transmitter "hacked" to get three positions on the third channel? I'm using the same transmitter and I have it set up for high/low gear only (two position, no dig).
Shift servo calibration using the 3ch 3position switch on the FlySky GT3C
TooOldForThis is offline   Reply With Quote
Old 11-10-2017, 08:13 PM   #24
Yessir, hacked. I bought the programmer, connection pins... soldered it up, connected to computer and hacked it.
I use the 3 position 3ch trim switch for the shifting.
Old 11-11-2017, 04:12 PM   #25
Thats great, the manual looks just like an axial one lol. Sweet build!
PileDriver is offline   Reply With Quote
Old 11-15-2017, 07:20 PM   #26
Question Re: Soze's GMADE GOM GR01 Build
So is it possible to setup the dig to be controlled separate from the low and high gears? I know you can set it up to use dig or not use it, though maybe I'm misunderstanding things.
One more question, How heavy are the seats in the Gom? I just picked up the seat from my Wraith and they're way heavier than they need to be so I'm eyeing the Gom seats as replacements since they look light.
HumboldtEF is offline   Reply With Quote
Old 11-15-2017, 07:52 PM   #27
I don't know if you could control it separately, but basically the setup for not using dig is to lock the shifting mechanism for the dig portion so that it never gets engaged.
To best describe it the servo shifting block sits between the shifting rods of the 2 speed and the dig.
In center/neutral position, neither rod is engaged and you are in 4wd + low gear.
In forward position, high gear is engaged still in 4wd.
In backward position, dig is engaged and you are back in low gear.
Didn't weigh the seats, but they do have some weight to them. They're also 2 piece as the seat cushion is a separate piece.
Old 11-19-2017, 11:49 AM   #28
Steps 75-86: Cage/Body/Cockpit
I'll add pictures of the body panels later, but was playing around with the cage to see what woudl be involved in getting to certain areas of the truck during maintenance.
So you can take the cage off as a whole piece. There's gotta be a way we can make this work by a hinge and fasten right?
Will be painting more details to the cockpit later.
EDIT: Here are the rest of the body pictures.
Painted with Tamiya PS-30 Brilliant Blue and Tamiya PS-5 Black
Old 11-19-2017, 11:50 AM   #29
Some work under the hood.
Picture of the Mamba X just fitting into the spot above the receiver box.
So as mentioned the receiver box is quite small. I'm using a FlySky 6ch receiver and it's just a tad too big for the box so I had to modify the receiver casing.
The receiver will only fit by putting it on its side.
Old 11-26-2017, 01:44 AM   #31
Steps 87-91: Wheels and Tires
Stuffed the stock GMADE MT-2202 Tires with Pro-Line 2.2 Single Stage Rock Crawler Foam
Old 11-26-2017, 03:45 PM   #32
Looking good man let us know how the shift fork works I have been thinking of upgrading to it.
Barndog Racing is offline   Reply With Quote
Old 11-29-2017, 07:24 AM   #33
Looks like any standard size/type servo will do for shifting? Have not started my build as of yet, been reading and picking up tips here and there. Appreciate all the advise i find here on the forums.
99crawler is offline   Reply With Quote
Old 11-29-2017, 09:13 AM   #34
Yes, a standard size servo is used for shifting. I'm getting good results with a cheap one that has basic specs, but I've seen others talking about a need for high torque. It sounds like the shifting mechanism isn't working smoothly for everyone, which creates the need for more torque.
Old 11-29-2017, 09:59 AM   #35
I'm just using a Savox 254MG because I had it lying around. It's got 7.2kg of torque. I think it'll do fine in there.
So far the shifting fork does seem to slide more smoothly when transitioning between high and low gear. It seems like less sticking on the way back to low gear from high if that makes any sense. This was just minor bench testing and I've yet to take it out for a good run.
Old 11-29-2017, 10:02 AM   #36
Moderator
JatoTheRipper's Avatar
Such a good looking truck. And that interior is sick!
Old 11-30-2017, 01:36 AM   #37
Added a few more things...
Aluminum Shock Upper Balls (available on eBay) (one is already on the truck)
GMADE GOM Sway Bar (available on eBay)
Old 11-30-2017, 01:46 AM   #38
It's starting to get to the finish line. Minor decals added. I really love the way this truck looks.
By no means complete yet, as I still have some parts to put on..... but I will be running it soon.
Old 11-30-2017, 03:29 AM   #39
looks great have to agree with the looks part. One of the best looking kits out there at present (IMO)
tachikoma1373 is offline   Reply With Quote
Old 12-01-2017, 05:31 PM   #40
Soze, just started my build and just finished the axles. Did you experience any gear mesh issues? One of my axles gear mesh is very rough and not smooth at all. I have tore it down once and re-greased with no luck. Appreciate any suggestions.
Soze's GMADE GOM GR01 Build - Similar Threads
Soze's GMade Sawback 4LS soze G-Made Sawback 23 12-31-2021 12:59 PM
Coming soon .....GMADE GOM-GR1 Rock Buggy big1717 G-Made Crawlers 951 05-12-2019 02:43 PM
Soze's MST CFX-W Build soze Max Speed Technology CFX 90 01-31-2019 01:02 AM
New Gmade USA GOM Rock Buggy Kit - In Stock! RPP Hobby RPP Hobby 0 10-05-2017 10:30 AM
New Gmade USA GOM Rock Buggy Kit - Open for Pre-Order! RPP Hobby RPP Hobby 0 08-31-2017 10:17 AM
