Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > G-Made Crawlers
Thread: Please help
Old 01-16-2020, 01:01 PM   #1
Default Please help
I just got the r1
Where can I mount the batter besides on the front axle
Mine is just not gonna work there
Sent from my SM-G965U using Tapatalk
aiden102408 is offline   Reply With Quote
Old 01-16-2020, 01:41 PM   #2
Default Re: Please help
There's mounts that'll (kinda) fit a full size pack inside the rear of the cage, they were included in the kit. That said, you'd be MUCH better served to just get a much smaller battery instead.
TheLetterJ is offline   Reply With Quote
Old 01-16-2020, 01:44 PM   #3
I actually just thought about that .. what size battery would you say? I dont want it to die in an hour lol
It has the ezrun 1040 esc
Old 01-16-2020, 02:00 PM   #4
I ran an 850mah 3s and it was good for 25-30 minutes of constant crawling, longer if just trail use, then just swap it out when it died. I know there's room for bigger, but I don't have an R1 anymore so I'm unable to measure. I'd bet you could find something in the 3000mah range that'll fit, but you'll have to measure and see.
Old 01-16-2020, 02:03 PM   #5
Here's a bit of info on it...
Gmade R1 Battery Size
and
R1 battery placement
chevy42083 is offline   Reply With Quote
Old 01-16-2020, 02:06 PM   #6
I think what I'm gonna do is put a piece of plexi glass on the rear axle and make something to hold it above the rear links
Old 01-16-2020, 02:29 PM   #7
and
I actually just came across these
They were in my mini revo way back when
None of them are puffing and theirs no tears in the outer plastic
