Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > G-Made Sawback
Thread: cv joint grease
Old 02-17-2018, 06:25 AM   #1
Default cv joint grease
i have tried all kinds of oil and grease on my cv driveshaft joints and front cv axle joints and everything i have tried attracts dirt.i tried spray silicone,did not attract dirt but after a few miles of walking trails joints started squeaking.any ideas on this?thanks
thead is offline   Reply With Quote
Old 02-17-2018, 08:57 AM   #2
Default Re: cv joint grease
Any sort of lube that is dry will work. I use this on mine:
Remington Rem DriLube aerosol https://www.amazon.com/dp/B0000C50JZ..._bcfIAb0QDXEMT
You could also use graphite or any other dry Teflon lube. Or just very lightly grease them and clean them after every run.
EZCompany is offline   Reply With Quote
Old 02-17-2018, 12:52 PM   #3
Moderator
JatoTheRipper's Avatar
I've used Ballistol on some of mine.
Old 02-17-2018, 12:55 PM   #4
what is that?
Old 02-17-2018, 02:15 PM   #5
Originally Posted by thead View Post
what is that?
Ballistol is another brand aerosol lube.
cv joint grease - Similar Threads
Universal axles (Axial)... grease or no grease TacoCrawler Axial SCX-10 15 11-14-2013 12:27 PM
Brazing help! Adding to existing joint? Joint Repair? Propane Tools, and Procedures 10 11-20-2011 10:19 PM
which driveshaft to get ??? 97mm joint to joint DAN8701 General Crawlers 0 05-02-2010 12:25 PM
