01-29-2009, 01:34 AM | #81 |
Rock Stacker Join Date: Oct 2008 Location: South Africa
| quick pic ... |
01-29-2009, 01:20 PM | #82 |
Quarry Creeper Join Date: Nov 2008 Location: London UK
Hats off to you Desmond, you've put a huge smile on my face this evening....
01-30-2009, 03:23 PM | #83 |
thanks Neely , its people like you and the forum that keep me going .... had a couple of things break , like just after this pic the one mount for the front diff broke off , fixed and strengthened now , Im slowly "tuning" this "toy" to make it better still , been playing with springs to get better articulation ....will post up some vids when Ive got it sorted to the max it can go .... |
01-30-2009, 03:39 PM | #84 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
i got to hand it to you, that is a very cool looking truck, great job using what you had to make it happen. |
03-17-2009, 07:37 AM | #85 |
| new body
Well , the old body is gone , it was too heavy and also too top heavy , it was made of thin steel but still weighed in at 900 grams , thats almost 1 kilogram , or 2.2 pounds. So I built a new body from a plastic waste bin ( dont laugh now...) , mounted it lower and it weighs Very little .... i also made stickers (at home) of all the manufactures that Ive used (yes incl B&D) , with less weight it performs much better , less rollovers and steeper climbs ..... Last edited by buju; 03-18-2009 at 03:40 AM. Reason: edit |
03-18-2009, 08:54 PM | #86 |
NICE! You never fail to amaze me with the stuff you make .
03-19-2009, 10:02 AM | #87 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Desmond, you are the king of resourcefulness. Where others only see a trash can, your imagination takes off from there. Incredible. Bravo!!! Keep it up man! |
03-19-2009, 10:43 AM | #88 |
Rock Crawler Join Date: Jun 2008 Location: Naples
Bliksem boetman! I like it, You have taken 'scratch built' to a new level, I know how resourcefull S.Africans are, but this takes the cake. Good job. Baaie kopkrap ne'. |
03-19-2009, 10:50 AM | #89 |
Quarry Creeper Join Date: Jan 2008 Location: Cyprus
WOW you made that body out of a trash can???? I admire you determination and resourcefulness, like everyone else |
03-19-2009, 02:35 PM | #90 |
Thanks guys , I really appreciate it , Well you know its not that difficult , this is basically how i did it: make a basic drawing of what you want , now try to imagine it in 3d , make some scale drawings on paper or cardboard , cut them out and tape or fold them together to make the 3d body , make adjustments to your paper body as you would like it , lay it out on the plastic and cut out. to bend the plastic without breaking it use a soldering iron to scribe a line on the inside of the fold , try to go about half way through the plastic without going through it , now while its still warm bend it and hold for a +- 1 minute , always bend slightly more than you need , IE: if you want a 90 deg. bend then bend the plastic 110 deg. , when you let go the plastic will come back to 90 deg. angle - simple..... use a plastic that is bendable , plastic that is to rigid or brittle will just crack and break. To make decals / stickers is also easy: find what you want on the web , copy to your pc , use a graphics program to re size and print it on plain paper , now use clear varnish and paint it over your print , do 1 quick cote (chemical varnish will cause the ink to run if you cote it too thick ) and when dry do another , cot both sides , now cut it out and use a thin layer of household glue to stick it on - easy - done.... |
03-19-2009, 02:43 PM | #91 |
RCC Addict Join Date: Jun 2007 Location: San Antonio, Tx
i like the new body man good work keep it up!
03-19-2009, 03:03 PM | #92 |
Pebble Pounder Join Date: Sep 2005 Location: West Coast Canada
Looks good, but where do you put your garbage now? :-P
01-01-2011, 01:24 AM | #93 |
Ive finaly made a blog of this build , for those interested you can view it here: http://buju357.blogspot.com/2010/12/...k-crawler.html |
01-01-2011, 02:14 AM | #94 |
Rock Crawler Join Date: Sep 2009 Location: Temecula Ca
WoW What a great Build I live the way you up grade threw out the build wish there where more build on here like this, Cant wait to see what next |
01-01-2011, 05:26 AM | #95 |
Pebble Pounder Join Date: Aug 2006 Location: B.C. Canada
I must say buju, as a guy who started out building custom crawlers this was a thrill to follow along with, great job. All in all what was the total cost of the build?
01-01-2011, 07:41 AM | #96 |
Quarry Creeper Join Date: Oct 2010 Location: sulphur
wow is all i can say, very creative man,
01-01-2011, 08:42 AM | #97 |
built not bought totally amazing you deserve a big hand you brought back alot of memories THANKS |
01-01-2011, 01:07 PM | #98 | |
Im now busy working on a independent suspension crawler with a single motor. the biggest problem with independent suspension is to get lots of movement / articulation. | |
01-01-2011, 02:41 PM | #99 |
Nobody Join Date: Sep 2008 Location: Maine
This was pretty fun to readstark start to finish for the first time. Great build. Where did the trash can body go? That thing was pimp!! |
01-01-2011, 03:06 PM | #100 | |
just goes to show - looks are everything ....... | |
