02-11-2010, 11:08 AM | #21 |
The only thing that is really gonna change is the space that the uppers are mounting on the axle. They are being spaced out further. The pivot point isn't changing. Same thing that I did on the front of my Berg with 86jeep's steering kit. It moved the upper mount away from the gear case a little, so I compensated it with a spacer. |
02-11-2010, 11:35 AM | #22 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
a perfect example of offset link mounts is my GX2 Gear Case Link,,it mounts to the gear case of the Bully axles and is really offest but it pivots on center at the chassis,,the fact that i have zero axle steer confirms that it works
02-11-2010, 11:46 AM | #23 |
Like a boss... Join Date: Feb 2008 Location: NorCal
rmdesignworks - thank you that's what I was hoping to hear. It's because the action points (rod/ball ends) are in the same place, correct? Which is why my pencil example is different, then. Cool. constantmotion - honestly, 86Jeep's kit is really the source of where this question is coming from. I carry his kit in my store and everyone locally has been afraid of it, because of the offset upper link mount. I wanted to be able to intelligently counter anyone's concerns. I just wish the 86Jeep kit would work with clocked axles :-(. Thank you! |
02-11-2010, 11:51 AM | #24 |
i have been trying to get my hot little hands on a set of berg axles so i can cad some parts for them and get the GX2 chassis set up for them,,,oneof the things i really want to work on is the upper link mount but also the axle link mounts
02-11-2010, 12:27 PM | #25 | |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
If you put a 10mm spacer between the link mount and the axle, you'll be fine, if not, refer to my first post. | |
02-11-2010, 12:51 PM | #26 |
Joe look at the picture included from constantmotion post #21, that is specifically what I am referring to.
02-11-2010, 07:38 PM | #27 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Man, you guys need to learn how to read. |
02-12-2010, 09:38 AM | #28 |
Rock Crawler Join Date: Oct 2008 Location: Florida
here is a pic of mine and there is no negative effect. |
02-12-2010, 02:35 PM | #29 |
Quarry Creeper Join Date: Sep 2008 Location: Kuala Lumpur, Malaysia
I see that you have now added the ball locations in your drawings, and they are where I assumed them to be. As I said earlier, your suspension will not be affected. The important things are the position of the balls, and the straight line distances between them. That is what determines the geometry of the linkage set-up. If those don't change, the suspension will not be affected. It doesn't matter if you run 'Z' shaped links and a gooseneck shaped link mount, as long as the balls don't move the geometry will be the same. Your good, run with it. Cheers. |
