04-02-2006, 07:17 PM | #81 |
Rock Crawler Join Date: Dec 2005 Location: houston
Looks great, excellent quality work as usual!!One question though, why not roll the rear axle straight up for clearance? Awesome rig!
04-02-2006, 07:26 PM | #82 |
Rock Crawler Join Date: Oct 2005 Location: Clarkston, MI
Why did you decide to chop the project? That was one of the ONLY nylints that I actually liked. I still like it though, just not as much.
04-02-2006, 07:36 PM | #83 | |
Quarry Creeper Join Date: Aug 2005 Location: classified
Here's a few more: | |
04-02-2006, 10:28 PM | #84 |
Quarry Creeper Join Date: Jan 2006 Location: Reno
how well does that tire cut pattern work? cuttin every other strand
04-03-2006, 06:51 PM | #85 |
Rock Crawler Join Date: Jan 2006 Location: Dallas
how did you cut the tires soo clean?
04-04-2006, 06:15 AM | #86 | |
Just a little healthy advice. | |
04-04-2006, 07:49 AM | #87 |
i thought i read all the posts, must of skipped a page, sorry
04-04-2006, 03:31 PM | #88 |
Newbie Join Date: Feb 2006 Location: USA
i noticed u were using a duratrax esc.i have the same one and i was wondering if there is a way to disable the reverse delay? i could not figure it out?
04-04-2006, 07:40 PM | #89 | |
04-07-2006, 02:55 PM | #90 |
I did some more work to the suspension on this thing. I moved the shocks inward and I made a new front upper link mount. Nylints Rule!!!!! |
04-07-2006, 08:16 PM | #91 | |
Thanks getbent, and thanks for the tip! You know I never really liked the look but I might give it a try. Is that the way you run your rig? I might have to cramp on your style. | |
04-11-2006, 06:26 PM | #92 |
New stuff: Parma MLST Xciter body, lowered body mounts and flipped up the rear axle. Lmk what you think! |
04-11-2006, 07:24 PM | #93 | |
Thanks dez for the comments. I'm looking foward to a good Nylint build from you. :-P | |
04-11-2006, 07:34 PM | #94 | |
04-11-2006, 09:38 PM | #95 | |
BTW, make sure you post a link to your 2.2 TLT build up when you get started. I may need a little inspiration to stray from the cheapness of the nylint!! | |
04-14-2006, 02:51 PM | #96 | |
04-16-2006, 12:32 AM | #97 |
I didn't see where you had listed the new wheel base after you chopped it, so...... What's the wheelbase? I am starting a build kind of like yours and will be using the stock wheels and tires (with Lt. Dan style trimming, hope you don't mind!)and wondered if you had a suggestion for wheelbase with the smaller tires. |
04-16-2006, 05:35 AM | #98 | |
The tire cutting is a pain, be sure if you use a Dremel with a wire brush that you don't go over 10,000 rpm. I tried it at full speed(20,000rpm) and it shredded the brush apart and made a real mess. You can really soften them up if you do the whole tire with the brush and not just the treads. Good luck, and I can't wait to see what you come up with!! You always do great work! | |
04-16-2006, 09:58 AM | #99 |
Looks like a Clod with an NN, a cut Parma LST ExCiter body, and cut 1/6 Nylint tires. But looks can obviously be deceiving.
04-25-2006, 04:41 PM | #100 |
Pebble Pounder Join Date: Apr 2006 Location: meriden
probably an old post to bring up, but i am really interested in making an exact copy of what u did. my question was how did U mount the moab tires and rims, and which chassis did U like the best. i read the whole entire post like 10 times, and got the following info... the bottom of the first chassis is 3" long, u used faberware to build the chassis, the chassis is 2.5" wide, u used 4" shocks mounted in the standard position ( but on the side), u used Dubro rod ends w/ metal balls, 4/40 threaded rods, and 3/16" tubing. what i also want to know is how long the pieces were that u used to brace the two plates. also how long the upper rods had to be, and if the stock ones from the first chassis had to be shortened when u put the second designed chassis with the flipped rear axle? and what did u use to mount the lower links? looked like a "u" shaped bracket.. did it come off of something? and in what spot did u screw them in? how long where the screws used to mount the "u" shaped bracket, and did u use a nut at the other end of the screw inside the gear box's.. helping me answer these question would be greatly appreciated...i think i spelt that right? -Josh A.- |
