10-19-2011, 08:05 PM | #1 |
Pebble Pounder Join Date: Aug 2005 Location: coshocton
| Sportsman Rig PICS
Post up your sportsman rig with details.
10-20-2011, 09:08 AM | #2 |
Quarry Creeper Join Date: Nov 2007 Location: NH
u first
10-20-2011, 03:07 PM | #3 |
Let's see |
10-20-2011, 06:09 PM | #4 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
I have my old comp rig that would be considered a Sportsmen rig, named Mugsy the comp buggy Homemade Cromoly Tube chassis TLT axles with RCP CVD's and gears Stealth tranny HPI 4" shocks tires and wheels change depending on use. Currently its setup for a King of the Hammers style race called, King of the Bean. |
10-20-2011, 06:52 PM | #5 |
Nice work! Looks awesome.
10-20-2011, 06:57 PM | #6 |
I wanna be Dave Join Date: Dec 2008 Location: ?
Sweet thread Bust out those SPORTY"S |
10-20-2011, 07:21 PM | #7 |
One of the very few trucks of mine that remains built. EP's 'Sportsman' SSS Axial 4 pounds 9.0 ounces RTR Tekin FXR Spektrum micro RX Holmes 10 turn CDW 6 mm transmission outputs HPI RS4 high speed (36/14) optional gears in front HPI E Savage HD gears in back HPI Wheely King 6 mm axle inputs Traxxas Maxx shafts MIP CVDs Axial aluminum stuffs Panthers Eritex wheels Last edited by EeePee; 10-20-2011 at 07:32 PM. |
10-20-2011, 08:32 PM | #8 |
Hey, Gotta question regarding the sportsman class. is their a guideline that says what can and can not be used in the sportsman class? I know that digs are not allowed and they have to be shaft driven. What else? -Gary |
10-20-2011, 08:36 PM | #9 |
Rock Crawler Join Date: Mar 2006 Location: Arrowhead Diggin
My Bug FXR Futaba Receiver Integy 35 turn JR 9100 servo Traxxas Shafts Stock ratio gears in the front Under drive in the rear GC-2 Chassis (rockin the old School) DH up front with 585 hubs and SLW v1s in the rear with 350 hubs. |
10-20-2011, 09:57 PM | #10 | |
I know for Tube chassis there are minimum chassis dimensions as well. | |
10-20-2011, 10:50 PM | #11 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
Here is my "OG" Frogger build. Older picture now is running Lipo's. |
10-20-2011, 11:21 PM | #12 |
Rock Crawler Join Date: May 2010 Location: Belfield NSW Australia
these are the rules that we use at cANZ this year 2011 - Crawl ANZ Competition Class Regulations 1. General Class Regulations:: 1.1 Vehicles are limited to 4-wheeled vehicles only for 2.2 classes. A maximum of eight ( driven wheels is allowed for Scale and Super classes. These wheels can be the only source of propulsion for the vehicle. 1.2 All vehicles must be electric powered only. 1.3 Bodied vehicles: 1.3.1 Any support chassis allowed (Except Scale Class). 1.3.2 Super & 2.2 Class bodies must be 76mm minimum height on sides. 1.3.3 No less than 317mm total length and full original width, and no less than 127mm across the centre (Except Scale Class) 1.3.4 All bodies should resemble its original form (Jeep bodies look like a Jeep) 1.4 Bodiless vehicles: 1.4.1 Must be a self-supporting, structurally complete, rigid frame. 1.4.2 2.2 Class Overall bodiless dimensions must be 203mm long, 76mm wide and 95mm tall. 1.4.3 Super Class Overall bodiless dimensions must be 305mm long, 76mm wide and 95mm tall. 1.4.4 The roof must be raised a minimum of 25mm from the main chassis to resemble a cockpit. 1.4.5 The frame sides must be an overall minimum of 25mm tall. 1.4.6 Bodiless vehicles should resemble a 1:1 vehicle. 1.4.7 Bodiless vehicles must have solid bonnet panel, solid roof panel and a minimum of 2 solid side-panels. 1.5 If at any point during a run your vehicle falls out of the vehicle specs for its class, for any reason, you will be required to take a touch penalty and correct the problem. 2. 2.2 Sportsman Class: 2.1 Vehicle wheelbase is limited to a maximum of 317mm. 2.2 Vehicle is limited to 2.2 inch wheels/rims or smaller at the bead surface. Tires may be modified from other sized tires using only a pliable rubber but must not exceed a total uncompressed outer diameter of 152mm. 2.3 Steering linkages are to be in front of the forward axle only. This includes the servo horn, steering links and steering knuckles. BTA (Behind the axle) and OTA (over the axle) steering configurations are not allowed. 2.4 Any combination of Radio and onboard electronics may be used; however, the only control the Driver is to have over the vehicle is for throttle and steering. You cannot control any other functions, either mechanically or electronically. 2.5 Vehicles must be shaft driven only and powered by a single motor, no MOA (motor on axle) axles are allowed. |
10-20-2011, 11:22 PM | #13 |
this is my sportsman my specs are on my signature |
10-22-2011, 04:57 PM | #14 |
10-22-2011, 05:20 PM | #15 |
10-22-2011, 05:43 PM | #16 |
RCC Addict Join Date: Jun 2008 Location: Amish Buggy PA
Here is my baby, the LCC makes a formidable opponent in the sportsmen world. I havent had a chance to clean and go over her since the summer series but you get the drift. Specs: Novak Goat 18.5 Hitec servo 5955 Dlux Knuckle weights Custom bent lower links Ti Uppers Stock chassis Losi Crawler shocks HD Gears Thats pretty much it nothing overly fancy but a great working truck. |
10-24-2011, 08:44 AM | #17 |
Gotta be more, let's see em.
10-24-2011, 02:05 PM | #18 |
Quarry Creeper Join Date: Dec 2010 Location: gastonia
| Dubbed The Mean Bean for obvious reason Fastback chassis FXR 35t pro motor BEC Stock axles DH fronts stock rears with Sedonas and custom foams thats bout it threads here new Fastback "The Mean Bean" |
10-24-2011, 05:53 PM | #19 |
Here are a few of mine: Just a basic GC3A with built axles and trans, 16T Brood motor, mamba micro pro and 3s lipo. Our sportsman trucks run the same courses as the 2.2 pro trucks......I took 1st place in 2.2 pro this past weekend and I did better on these courses with my sporty truck than I did with my berg! Last edited by JeremyH; 10-24-2011 at 05:55 PM. |
10-24-2011, 05:57 PM | #20 | |
