06-14-2006, 02:43 PM | #41 |
Rock Crawler Join Date: May 2006 Location: Burrillville, RI
I think I found a 1:8th scale body that I might buy. The body is a little skinnier but the wheelbase looks correct.
06-14-2006, 03:01 PM | #42 | |
Quarry Creeper Join Date: Apr 2006 Location: winchester
im just say n i got 6 of these things that i work on cause my buddys dont have a place to work on theres. so when we go out and mine goes up and over something and my friend's doesnt cause the 1/6th body is getting hung up or also in many occasions when attempting rock climbs more weight gets transfered to the rear and takes pressure off the front making it impossible for the front to get traction and PULL itself up thats whats up only place where the 1/6th body helps is on dirt | |
06-14-2006, 06:52 PM | #43 |
Pebble Pounder Join Date: May 2006 Location: Southbury
I agree with you when talking about just performance in MOST situations, But I've also climbed stuff with the body on that it won't do without it...for whatever reason. I really just like the scale look more than anything. |
06-14-2006, 07:26 PM | #44 |
Rock Crawler Join Date: Mar 2006 Location: Dayton
different strokes for different folks...some prefer scale, some prefer what works best. personally i prefer the scale look, but im sure 12flex's crawler will out-perform mine easily. -Dalton |
06-15-2006, 11:34 AM | #45 |
agreed... I am now in the middle of lowering the whole thing. The COG is too darn high. I am also giving the body a HUGE diet to reduce the weight. I tore out the floor and seats and will be making some custom doors to partially hide the missing floor. This should lower the body about 2". I am also relocating the fron and rear shock mounts upward. This will give me about 1-2" lower height in the middle, but I am hoping that lowering the COG will offset the loss in height in the center. It look like the total height of the rig will be about 3-4" lower which should help drastically. Scott |
06-16-2006, 07:06 PM | #46 |
I think this weekend I am getting rid of the chassis, well at least partially. I just bought a bunch of aluminum to build a frame of sorts. I may make it a hybrid of sorts. Jeepers steering mod is looking better and better. Then I will have thin axles(for a Nylint) front and rear. Pictures to come....
06-18-2006, 06:12 AM | #47 |
ok... so I lowered the whole thing a bit and it has helped tremendously. Climbs that I used to flip over backered on , I can shoot right up them now. Off camber stuff is a lot better now too.. here are some pics.. sideview: crap... I will have to resize these later on |
06-18-2006, 08:18 AM | #48 |
Rock Crawler Join Date: Feb 2005 Location: Hardin, KY
about a new frame, you could make one like mine....looks like you dont have much uptravel anyways..... |
06-18-2006, 05:58 PM | #49 |
yeah...not much up travel in the back...but when you lift the back it sags more than an inch.
