Thread: Xr10 viper 2 upper link help!!
Old 07-11-2012, 04:34 PM   #1
Exclamation Xr10 viper 2 upper link help!!
Hey guys i am buying the viper 2 chassis for my xr10 and i need help on what links i should buy for the upper links? What ones are they im new to this whole thing and i need help!!! Where can i find them? Thanks
Joshperin is offline   Reply With Quote
Old 07-11-2012, 04:37 PM   #2
Default Re: Xr10 viper 2 upper link help!!
here ya go
Tydl's Viper 2
and welcom to rcc.
richardgarrett56 is offline   Reply With Quote
Old 07-12-2012, 10:34 AM   #3
Thats sick but what upper links are they?
Old 07-12-2012, 11:07 AM   #4
For my Viper II, I used some straight axial links, I think they were left overs from my Wraith kit.
The fronts are AX10 Lowers, that I bent in to an s-shape with a tubing bender, just like the ones you get from the parts store.
Then shortened them up with my dremel, re-drilled the holes, and tapped them.
So far the aluminum is working good. Can't run Revo ends on them, but they are working OK. No rod end failures yet.
The plan is for something custom in the future.
And those Berg guys think we don't fab stuff..
bigstu is offline   Reply With Quote
Old 07-12-2012, 12:33 PM   #5
his name is wade and he is a team member of ugc,im sure he would be happy to help you with what ever questions you need answer too. send him a pm. tydl or dickyt
Old 07-12-2012, 02:04 PM   #6
Tydl's upper links are an old set of Ti links I made and then gave to him when I switched from XR to Berg.
They are lunsford links that I bent. It has been almost a year and a half since I gave them to him, so I can not recall the lengths I ordered, but 90mm and 110mm rings a bell, but may not be correct.
DickyT is offline   Reply With Quote
Old 07-12-2012, 04:50 PM   #7
But is there good flex?
Old 07-13-2012, 04:08 PM   #8
More than enough if you mean articulation. We all have the shocks limited.
If you mean the links flexing? no, they are 4mm Ti, the don't budge much, but you don't want them too.
Old 07-14-2012, 09:16 AM   #9
Ya thats what i ment the articulation.. So its just the straight links from the wraith that will work?
Xr10 viper 2 upper link help!! - Similar Threads
XR10 with VIPER chasis - upper links help bikeboy Axial XR10 20 08-17-2011 01:24 PM
