05-17-2013, 12:59 PM | #1 |
Quarry Creeper Join Date: Mar 2009 Location: Yokota
| SCX10 Al Shock help
Looking for some home brew, DIY, cheep, light spring retainers. This is my problem I have al boddied SCX10 shocks and mini t springs. All I have for a retainer is the bulky al nut... to big! It binds my rear suspension on my 2.2s ringer. So what ideas are out there please post up what you got. Was thinking something with heat shrink but I think it will just lay over under pressure. |
05-18-2013, 10:07 PM | #2 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
| Re: SCX10 Al Shock help
What exactly do you mean by "bind"? As in the preload collar is rubbing on part of the chassis?
05-19-2013, 06:26 AM | #3 |
It is only affecting the rear of my truck where that nut has to sit is at the bottom and while there it makes contact with my upper links and that causes my rear suspension not to articulate fully side to side ( bind ) if I move the nut to the top the suspension cycles normally side to side. With about 1 to 2 mm to spear between the shocks and upper links on both sides. Sent from me using my DNA |
05-19-2013, 07:10 AM | #4 |
What if you turned down the ones you have now?
05-19-2013, 07:43 AM | #5 |
Pictures would be great. You may find that running Mini T rear springs or MRC springs will help. They are a longer spring and you'll be able to keep the preload collar higher on the shock body while retaining basically the same spring rate.
05-20-2013, 06:43 PM | #6 |
Quarry Creeper Join Date: Dec 2010 Location: Gaffney
If you flip them upside down that might help.
05-20-2013, 06:48 PM | #7 |
RCC Addict Join Date: Nov 2004 Location: union
I used a stock ax10 shock body and cut a section out of it to use a pre load collar. Cheap, light and works like a charm. Last edited by klabeaume; 05-20-2013 at 06:51 PM. |
05-22-2013, 03:00 PM | #8 |
Here is couple of pics wish I could do better but currently it is with Ittybitty getting a ESC. Sent from me using my DNA |
05-22-2013, 03:12 PM | #9 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
Really cheap and small is another set of shock caps for it and take off the top so it's just a ring and screw that on.. I've seen many people do that |
05-22-2013, 05:59 PM | #10 |
I was thinking that as I have the ones with the fake reservoir on it. Sent from me using my DNA |
SCX10 Al Shock help - Similar Threads | ||||
scx10 shock help! | bustamantealdo | Axial SCX-10 | 1 | 01-25-2013 11:53 AM |
SCX10 Shock upgraded Shock hoops | natskiboy | Axial SCX-10 | 15 | 05-18-2012 12:13 PM |
Scx10 Shock question | Crashhero29 | Axial SCX-10 | 1 | 12-15-2011 08:59 PM |
SCX10 shock question... | Heath49 | Axial SCX-10 | 9 | 01-07-2011 09:19 AM |
