08-31-2013, 10:15 AM | #1 |
I wanna be Dave Join Date: May 2010 Location: The east coast
| what is the heaviest diff oil out there? were do i get it?
Looking for some help. Wanting to stiffen up the front differential on my twin hammers (not full lock). I've heard people using 500k but it still had a little too much give. Anything higher? Any input is appreciated. |
08-31-2013, 10:30 AM | #2 |
Rock Crawler Join Date: Dec 2008 Location: Displacement
| Re: what is the heaviest diff oil out there? were do i get it?
Tra5039 Diff lube for the slayer. 500k (500,000) Thats the thickest I could find with out it locking the diff completely. It seemed to be a perfect harry medium. Almost acting like a limited slip. |
08-31-2013, 11:18 AM | #3 | |
| Re: what is the heaviest diff oil out there? were do i get it? Quote:
I thought I saw a post once of someone talking about 1,000,000 weight, but they might have been screwing with everyone. | |
09-02-2013, 11:33 AM | #4 |
Quarry Creeper Join Date: Jun 2012 Location: Earth mostly
There is some 1 million weight from Tamiya. I have some its more like a heavy grease than oil. I used it in my twin hammers diff but it was to thick basically locked the diff but it did have enough give I didn't break anything like I did when running the solid locker. I replaced it with 500k it works %95 as well as having 1 000 000 when crawling and still have me good high speed handling. With 1 000 000 I couldn't turn worth a frack.
09-02-2013, 11:33 AM | #5 |
| Re: what is the heaviest diff oil out there? were do i get it? |
09-02-2013, 11:36 AM | #6 |
I wanna be Dave Join Date: May 2007 Location: Fairfield ME
09-02-2013, 12:03 PM | #7 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
This is about the thickest I can find You can usually find it at all your local hardware and big box stores. . |
09-05-2013, 08:13 PM | #8 |
I wanna be Dave Join Date: Aug 2004 Location: central VT
I'm familiar with using both halves of JB Weld to make "spools", but which half do you use to make for a "limited-slip effect? Does the poster tack just get ground up into little bits after some abuse? |
09-05-2013, 10:03 PM | #9 |
09-06-2013, 07:05 AM | #10 |
| Re: what is the heaviest diff oil out there? were do i get it? The poster tack stays in one piece. After a few packs it its soft enough to still allow the dif gears to spin through it. It won't allow much diff action but it will act like a 1:1 limited slip with shimmed springs.
09-07-2013, 05:06 AM | #11 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
09-07-2013, 11:06 AM | #12 | |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Remember not to over fill due to case pressure will cause leaks. | |
what is the heaviest diff oil out there? were do i get it? - Similar Threads | ||||
do you need a sealed diff to use heavy diff oil? | jebster | Newbie General | 1 | 10-10-2012 07:13 AM |
Heaviest diff oil? | demonoid369 | General Crawlers | 6 | 11-19-2011 09:13 PM |
heaviest beadlock? | phillyb | Tires and Wheels | 20 | 03-05-2009 07:14 PM |
Diff oil | scruff007 | Tamiya TLT Crawlers | 3 | 09-22-2006 06:43 AM |
diff oil | nichols racing | Kyosho Crawlers | 5 | 05-18-2005 11:31 PM |
