Thread: Which shafty solid axle is best suited to run Jumbo Kongs?
Old 01-21-2005, 10:06 AM   #1
Default Which shafty solid axle is best suited to run Jumbo Kongs?
Looking at a project truck running a T600 motor, an E-Maxx tranny, and REVO shafts. Which axle would best handle the stress of a set of Jumbo Kongs; TXT-1, Twin Force, or X-Factor axles?
The center diffs would be replaced with lockers or locked via JB Weld if there aren't any lockers for the X-Factor axles.
BoilermakerFan is offline   Reply With Quote
Old 01-21-2005, 10:34 AM   #2
Default Re: Which shafty solid axle is best suited to run Jumbo Kong
xfactor or twin
DirkDigler is offline   Reply With Quote
Old 01-21-2005, 10:34 AM   #3
I would use the Force or the X Factor axles, the txt are strong, but they will let go at the end of the dog bone at the steering knuckle!
But that is just what I think, you can break anything!
Nitro is offline   Reply With Quote
Old 01-21-2005, 10:36 AM   #4
x factor twin or hybrid maxx axels but do not run maxx sliders for axels with kongs.
bigred is offline   Reply With Quote
Old 01-21-2005, 11:53 AM   #5
Thanks Guys.
Nope, no Maxx sliders. I run Maxx sliders on my TLT-10.
The shafts will be REVO shafts or possibly CVDs, but I'll start with REVO shafts.
I need to search a bit more, but I don't like the stock servo mount for the X-Factor axles with the huge skid plate. I did think the X-Factor axle would hold up better though since it's designed for a .25 nitro engine and the shock of the clutch engaging.
Old 01-21-2005, 11:58 AM   #6
Colt Python/SR9c
TwistedCreations's Avatar
i would run a Maxx hybrid axle with CVD's.. i run mine with LST's and have beat the livin crap out of it and still haven't broke anything on the axles( knock on wood)
if ya made a Maxx hybrid axle, to fit the CVD's you would want the WMS-WMS at 13"
just some measurement info for ya that is if you didn't use the stock a-arms. mine are made basically from 1/4" solid rod
TwistedCreations is offline   Reply With Quote
Old 01-21-2005, 12:29 PM   #7
I'm kicking that idea around since you can build a pretty bulletproof drivetrain with UE, RRP, and Kipster parts for the Maxx.
Old 01-21-2005, 12:37 PM   #8
Id go with Xfactor axles i have seen CVDs snap. 8O
skyjacker_rc_club is offline   Reply With Quote
Old 01-21-2005, 01:24 PM   #9
i say go with mad force axles unless they are the same as xfactor axles
fastmaxxcooper is offline   Reply With Quote
