11-14-2013, 04:26 PM | #1 |
Rock Stacker Join Date: Aug 2013 Location: Gallatin
| Wraith problem.
I have a wraith I put together my self as a kit. Everything works but I ran it the other day. It ran fine but it leaned to one side. I adjusted my shocks and that dident help I took them off and they seamed fine any ideas?
11-14-2013, 04:28 PM | #2 |
| Re: Wraith problem.
use some pre load spacers. problem solved |
11-14-2013, 04:54 PM | #3 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: Wraith problem.
Torque twist. It will always be visible in a shafty, unless you do something stupid, like put diff grease in your shocks instead of oil... |
11-14-2013, 05:10 PM | #4 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Wraith problem.
You need to flip the ring gear in the rear axle. It won't remove all of the torque twist, but it takes a lot out.
11-14-2013, 07:28 PM | #5 |
| Re: Wraith problem.
I've done the preload, flip the gears and all that and the Wraith still leans. I just got used to it. However, I like soft springs so it's mushy |
11-15-2013, 05:58 AM | #6 |
| Re: Wraith problem. |
11-15-2013, 07:43 AM | #7 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
| Re: Wraith problem.
I run a rear sway bar on mine, it takes most of the torque twist out, although it does limit the flex in crawling type situations.
Wraith problem. - Similar Threads | ||||
Wraith problem. | Browner93 | Newbie General | 9 | 11-28-2013 09:15 PM |
Wraith steering problem. Help! | Trentenowns | Axial Wraith | 5 | 08-20-2012 10:01 PM |
Problem with Wraith right out of box....... | HDMM | Axial Wraith | 14 | 06-22-2012 07:29 PM |
Wraith esc problem | uncle-speed | Axial Wraith | 11 | 10-28-2011 07:06 PM |
wraith problem | karrfab | Axial Wraith | 3 | 08-31-2011 12:59 PM |
