Thread: G6 kit front suspension issue?
Old 02-05-2014, 09:31 PM   #1
Default G6 kit front suspension issue?
So I am putting together my new G6 kit and I have a problem, the servo hits the chassis cross member right at full droop, so I have zero up travel, just wondering if anyone else had this issue? I'm glad I bought it from rpp and they included a free lift kit.
idaho is offline   Reply With Quote
Old 02-05-2014, 09:36 PM   #2
R2j
SORRCA Committee Member
R2j's Avatar
Default Re: G6 kit front suspension issue?
The battery plate mount cross member?
R2j is offline   Reply With Quote
Old 02-05-2014, 10:32 PM   #3
Lol yep, I figured it out, you shouldn't build kits while taking care of two small children, you end up putting things in backwards lol.
Old 02-05-2014, 11:48 PM   #4
Location: somewhere near Los Angeles...or a city looking thingy.
I was kind worried about the brace hitting my servo too but it had 2-3mm of space between the two. Just enough to fully articulate and droop.
OTHGbronco82 is offline   Reply With Quote
Old 02-09-2014, 01:04 AM   #5
I'm using a SAVOC servo, and it hits the battery mount cross member, without a servo horn on the servo. Think all I got to do is move servo back with different mounts.
Joe&Jeep is offline   Reply With Quote
Old 02-11-2014, 06:27 PM   #6
It is pretty normal to have to clearance the crossmember in front of the servo. Also typical to have to lightly clearance the inner part of the front shock tower crossmember to clear the servo mounts when fully articulated.
meatmonkey is offline   Reply With Quote
G6 kit front suspension issue? - Similar Threads
independent front suspension and front diff build canadian scx10 Axial SCX-10 1 02-13-2011 07:52 PM
Suspension issue, rear turning when flexed out JTTG Newbie General 13 11-03-2009 02:23 PM
suspension issue I think??? fisherkip Axial AX-10 Scorpion 1 10-15-2009 01:47 PM
front steering linkage behind front axle kit? slip408 Axial AX-10 Scorpion 8 09-14-2008 01:16 AM
