Thread: Holmes Hobbies motor wires problem!!
Old 05-30-2014, 08:39 PM   #1
Default Holmes Hobbies motor wires problem!!
Hello! I need clarification regarding if is ok to invert the ESC cables that go to the motor. I just got a new Holmes Hobbies motor, and after connecting the wires the same as with the factory motor (black/black & red/white) now forward is reverse and rev is fwrd. In order to correct this I had to switch the cables. Is it ok to do this?
traxx2003 is offline   Reply With Quote
Old 05-30-2014, 08:43 PM   #2
AddictedtoRC1's Avatar
Default Re: Holmes Hobbies motor wires problem!!
It is but you'll want to make sure your timing is correct. If it was advanced at all, it will now be retarded.
AddictedtoRC1 is offline   Reply With Quote
Old 05-30-2014, 09:14 PM   #3
Ok, I have to say, it does have a lot more power than the stock motor. And yes I had requested for it to be 6 degrees advanced . So how do I check to make sure that the timing is not retarded?
Old 05-30-2014, 09:36 PM   #4
The 0 on your can should be between the 0* and 12* as shown in the above picture. If so, loosen the endbell and just turn it the opposite way past 0 about the same amount.
Your motor should spin faster one way. That's the direction with advanced timing.
Holmes Hobbies motor wires problem!! - Similar Threads
Holmes hobbies, BR-XL Problem schulberger26 Electronics 6 03-19-2010 07:13 AM
Problem soldering wires to motor Tronk Newbie General 4 10-29-2006 05:58 AM
