Thread: What's the difference between ultimate yota I & II
Old 08-13-2014, 11:01 AM   #1
Default What's the difference between ultimate yota I & II
What's the difference other than the dual arm knuckle, replaceable diff cover, and $10??? I see they both use the same diff gears but are the axle shafts different? The yota II shafts stronger? Is it worth the extra $10 for the replaceable diff cover and dual arms I probably won't use anyway or are they actually stronger/better axle?? Anyone experienced with the two any input appreciated! Thanks
geislerj3 is offline   Reply With Quote
Old 08-13-2014, 12:52 PM   #2
Jeep whore
scale4x4's Avatar
Default Re: What's the difference between ultimate yota I & II
There pretty much the same besides the differences you mentioned. IMO just having the removable diff cover is worth the extra 10.00, having to completely tear apart the truck to grease the axles is a pain, and the yota II's have smaller dia. axle tubes.
scale4x4 is offline   Reply With Quote
Old 08-13-2014, 07:13 PM   #3
Oppan Gangnam Style
chino63's Avatar
From my experience....
The pros:
Steering is better with the yota 2, king pin inclination, dual output optional, more detailed housing.
The cons:
King pin inclination, steering arms are weak (I snapped one in a very mild tumble), king pin bolts barely thread into housing and strip easily(I recommend installing helicoils).
chino63 is offline   Reply With Quote
Old 08-15-2014, 02:32 PM   #4
Jus
That right there pisses me off... if I had known about it beforehand I don't know that I would have bought a Gelande II.
Jus is offline   Reply With Quote
Old 08-15-2014, 07:17 PM   #5
Oppan Gangnam Style
chino63's Avatar
I like alot of RC4WD's stuff and am not trying to bash on them but the finished product usually fall short in critical areas. Hate to say it again but poor engineering right there.
Old 08-15-2014, 08:02 PM   #6
I only had mine for a few month before I sold the toy they where on. but I had no problems with them, other than sloppy king pin bushings.
being able to run the tie rod behind the axle was nice. was a little sketched on running a brood onslaught motor with them at first. but after I stalled the motor out a few times from being all bound up, I had no second thoughts on hammering on them.
joeyf is offline   Reply With Quote
What's the difference between ultimate yota I & II - Similar Threads
What's the difference between pro4 & roc 412 Markeje Axial Wraith 9 04-18-2014 10:08 AM
Dinky R/C's Ultimate Yota Giveaway!!! muddauber7 General Crawlers 120 10-22-2011 10:39 PM
Yota Tundra Highlift vs. Land Cruiser FJ40 (Price difference) Mocca Master Tamiya CR-01 11 10-27-2010 09:36 AM
