02-26-2016, 09:04 PM | #1 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
| Overdrive gears!
Hey guys. I'm trying to volt up (3s) and gear down but I've run into a slight problem. My axial HD overdrive gears won't let go of my grip-fab ARB lockers for me to change to underdrive ring/pinion. I was planning on making a quick change to underdrive gears, but it's not going so quick, its actually not going at all, so I'm asking to see if anyone has had any issues with a 3s pack and overdrive gears? Since it would seem I need another set of lockers to use my new underdrive gears. Before I forget, this is for my Bomber, I've given it all the VP goodies I could find/collect, so its heavier now than when I took it out of the box, but it does have a holmeshobbies puller pro 3500kv XL, and a trail master BLE esc. I guess what I'm looking for is some solid info on how low I should gear the spur, and pinion until more lockers show up, or I should I just stick with the 2s shorty packs I've been using... |
02-27-2016, 06:43 AM | #2 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
| Re: Overdrive gears!
How hot does it run on 2s? If i had to guess i would say your fine. Just keep an eye on the temps. |
02-27-2016, 07:35 AM | #3 |
The spur and pinion have a lot more impact on the overall gear ratio than the differentials. I would leave the diffs alone and change the spur/pinion so you get ratio that is between 5 and 6. The Axial HD overdrive gears don't mesh as well as the HD stock and HD underdrive gears. So it is important to make sure they are shimmed so you don't have a lot of slop. (Not to tight with the shims either) |
02-27-2016, 08:50 AM | #4 |
I just had this issue with a felsenfest spool last night with axial OD gears no less. My solution was to back the ring gear screws out a couple turns and lay the ring gear across the jaws of my vice with the locker hanging in the gap. I gave the screw heads a few taps with the handle of a screwdriver and the locker popped off. The OD gears don't last as long since the gear mesh is craptastic but I've had no other problems with them on 3s. |
03-03-2016, 09:40 AM | #5 |
RCC Addict Join Date: May 2009 Location: Weston
You could also try heating the gear a bit (not too much) with a torch to expand a bit. Should fall off. |
Overdrive gears! - Similar Threads | ||||
overdrive gears.? | panama | Axial Wraith | 31 | 07-01-2020 01:28 AM |
overdrive gears | crawler pilot | Losi Mini-Rock Crawler | 13 | 11-29-2009 04:23 PM |
