03-12-2017, 06:49 PM | #1 |
Newbie Join Date: May 2015 Location: West Monroe
| Driveshaft preference
Is there any pro or con in putting the driveshaft female side on the output shaft in the diff or on the transmission? I have the idea that the male side should be on the bottom so dirt, sand and debris will come out... with gravity..... do that idea sound right?
03-12-2017, 07:53 PM | #2 |
| Re: Driveshaft preference
What vehicle, stock or aftermarket brand shafts?
03-12-2017, 08:11 PM | #3 |
TF2 with teraflex shackles.... I needed longer shafts so I had to put Junfac scx10 honcho length shafts under it. Sent from my iPhone using Tapatalk |
03-12-2017, 08:13 PM | #4 |
| Re: Driveshaft preference With the flex the shaft in the front would slide out using stock length. Sent from my iPhone using Tapatalk |
03-12-2017, 08:18 PM | #5 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
If your talking about MIPS, yes female on tranny output and male on axle pinion. That's how I run mine.
03-12-2017, 08:21 PM | #6 |
I am running junfac but in the picture you can see my setup.... hope it keeps crap out of em... Sent from my iPhone using Tapatalk |
03-13-2017, 01:46 PM | #7 |
Junfac much more scale looking than MIP, but prolly slightyl less strength. I run female end on pinions and male at transmission prevents rock rash on splines better and imo keeps dirt and junk out of them better.
03-13-2017, 01:50 PM | #8 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Always ran MIPs. Just got some Junfacs for my TF2, either I ordered the wrong length or Amazon mixed it up. Grabbed a cut of wheel, cut the 1/4" of spline off the female end Garbage. I'll weld it back up and clean out the bore, what a stupid (weak) design. |
03-13-2017, 04:52 PM | #9 |
For all my years I've run female at the axle so I don't trash the splines on the male side. Which happens.
03-13-2017, 04:54 PM | #10 |
That is a good idea.... good ole logic!!! Sent from my iPhone using Tapatalk |
Driveshaft preference - Similar Threads | ||||
OD/UD gearing preference | nsg1rc | Axial SCX-10 | 7 | 12-13-2015 08:42 PM |
Gear size preference? | Brainstain | General Crawlers | 4 | 04-23-2008 09:33 AM |
