Thread: flange bushing source/recommendations
Old 06-19-2017, 07:50 AM   #1
Default flange bushing source/recommendations
I want to replace some worn flange bushings mistly on various scx10 front ends. Any recommendations? need to do 3 rigs and get some spares. I dont mind spending a couple bucks for good hardware, but i drawn the line at 9.99 a front end.
Considering the lockedup oversized ones, unless someone has a better suggestion.
Ditchrat is offline   Reply With Quote
Old 06-19-2017, 07:55 AM   #2
Moderator
JatoTheRipper's Avatar
Default Re: flange bushing source/recommendations
What size do you need? Check McMaster-Carr
Old 06-19-2017, 08:25 AM   #3
Really, will do.. Thanks
Old 06-19-2017, 08:38 AM   #4
Moderator
https://www.mcmaster.com/#standard-f...rings/=184ybdr
Old 06-19-2017, 10:12 AM   #5
If you go to jatos link and select ID 3mm, only one option pops up and OD is 6mm. Thats going to be to big.
Check with dlux, he sells some for ax10 and wraith, and if it close enough, you can file some down for a no slop fit.
I got some ax10 bushings from dlux for my bully 2 knuckles, and filed down OD and top hat length a hair and worked perfect. No slop now.
84yoda is offline   Reply With Quote
Old 06-19-2017, 10:18 AM   #6
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 06-19-2017, 10:23 AM   #7
Is $6.99 an end too much?
Knuckle Bushings (4pcs) - Vanquish Products
Chiphead is offline   Reply With Quote
Old 06-19-2017, 11:19 AM   #8
Originally Posted by Chiphead View Post
Thanks for taking the time to look that up. What i should have said in the post i refuse buy vp products.
Old 06-19-2017, 11:51 AM   #9
Custom Carbon Fiber
Robbob's Avatar
These are Hex heads
https://www.tamiyausa.com/items/radi...king-pin-54237
These are Philips crew heads
TAMIYA*TA04*KING*PIN*SET...
Robbob is offline   Reply With Quote
Old 06-19-2017, 01:43 PM   #10
Oh, so scx10 are the same as a wraith? I didnt know they were the same. Hit up dlux for his wraith no slop bushings. Or those tamiya look good too.
Old 06-19-2017, 02:11 PM   #11
Thanks again everyone. I got some good ideas. Im going to grab some dlux or locked up flanges. But I'm going to order up some plain old 3mm shoulder bolts to try out, also
flange bushing source/recommendations - Similar Threads
Knuckle flange pipe help ApeMac15 Axial Wraith 5 05-17-2012 05:41 AM
Traxxas bushing vs. HPI bushing. day215 Axial XR10 9 10-07-2011 06:00 AM
Window Flange? kc092755 1.9 Scale Rigs 0 06-16-2011 04:36 AM
axle flange.......... bob1961 Axial AX-10 Scorpion 6 11-14-2008 05:05 AM
