01-06-2018, 08:33 PM | #1 |
Newbie Join Date: Oct 2015 Location: Aynor
| Driveshaft binding with lift
I got the scx10 ii and just got 2.2 mudslinger so I lifted it so they fit and my MIP drive shafts bind. I was going to do a trans drop lift kit but the scx10 ii stock axles you can not do a servo on axle the only other thing I could think of is clock the axles. Any input on what could help
01-06-2018, 09:12 PM | #2 |
| Re: Driveshaft binding with lift
lose the lift kit, they are worthless, get some 4.75 Hyrax or similar 1.9 tires if you want bigger tires. All your current setup is good for it binding driveshafts and being top heavy...
01-06-2018, 10:42 PM | #3 |
Rock Crawler Join Date: May 2013 Location: Dallas
^ this
01-06-2018, 10:55 PM | #4 |
| Re: Driveshaft binding with lift No need to swap back to some tiny tires now that you spent the money on what you want. Lose the lift kit and trim the body as needed. Limit the shocks if you don't want to trim a lot. |
Driveshaft binding with lift - Similar Threads | ||||
Yeti Kit rear driveshaft binding? | Mattwarner | Axial Yeti | 1 | 01-13-2016 07:26 AM |
Front Driveshaft Binding | snakeman | Kyosho Crawlers | 6 | 12-04-2015 01:19 AM |
Lift kit/driveshaft issue | Bn2h8 | Axial SCX-10 | 6 | 04-23-2014 08:01 AM |
Wheel hex & driveshaft binding problems | Frost | General Crawlers | 5 | 10-02-2007 05:02 PM |
