09-15-2018, 09:43 AM | #21 |
| Re: Esc
MMP is a good esc. I would like it, if you have the castle link you can set a throttle curve for better low speed control. The HW wp 1080 is only $40, the 80$ one i was referring to is the castle sw4, most of the castle ones are obout the same if you stick with brushed motors, as far as I know. Some have a stronger drag brake.
09-15-2018, 12:06 PM | #22 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
| Re: Esc
Didnt get a vid today, sorry guys. Although i got my new driveshafts in today. While i was piddlin n puttin them in, i tryed a 3s on my xl5. It lit up green til i either turned the wheels or squeezed the trigger. If i can run 3s on my xl5, how do i set it up to do so? Sent from my SM-J327VPP using Tapatalk |
09-15-2018, 12:17 PM | #23 | |
Quarry Creeper Join Date: Apr 2018 Location: US
| Re: Esc
It should be good to go, do you have the XL5HV from the TRX4? Mine could go from 2-3s no problem. Quote:
09-15-2018, 03:41 PM | #24 |
| Re: Esc
No, mines not the HV. Thats y i was sayin it wont work in 3s. I know the HV version will Sent from my SM-J327VPP using Tapatalk |
09-15-2018, 05:57 PM | #25 |
| Re: Esc
Ok, I still believe it could. But I may be wrong. Sent from my Pixel 2 using Tapatalk |
09-16-2018, 08:32 PM | #26 |
Rock Crawler Join Date: May 2018 Location: USA
| Re: Esc |
09-16-2018, 08:45 PM | #27 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: Esc |
09-17-2018, 03:25 AM | #28 |
| Re: Esc
I tryd it on 3s n the light just blinks. I happen to find an el cheapo esc i had got in a lot of parts. It works ok. Definantly has more wheel speed now. But the esc has a glitch in it. It wants to jump every once in a while without touchin the throttle. So im still in market for n esc. Im beginning to wonder if the xl5 ive got isnt in trainin mode. Thought bout that after i swapped them out smh Sent from my SM-J327VPP using Tapatalk |
09-17-2018, 09:40 AM | #29 | |
| Re: Esc
Well you certainly can't go wrong with the Hobbywing 1080. Or if you want to stay with Traxxas, the XL5HV is actually pretty nice honestly. Quote:
09-17-2018, 12:37 PM | #30 | |
| Re: Esc Quote:
Sent from my SM-J327VPP using Tapatalk | |
09-17-2018, 12:39 PM | #31 |
| Re: Esc
Sounds good. If you're interested, I have the XL5HV from my TRX that I'd be willing to part with cheaply. Sent from my Pixel 2 using Tapatalk |
09-18-2018, 05:07 AM | #32 |
| Re: Esc
I went from stock axial electronics to an HW1080 and was blown away by the performance difference. Then I paid 30$ more and was extra blown away by a Castle Mamba X Micro and its performance difference. Those are both two very reasonable price points with very noticeable improvements. The XL-5 series is absolute shit IMO and I would never recommend them to anyone. Im sure some people have good luck, but I havent had a single Traxxas electronics piece, be it esc, receiver, or servo that hasnt failed.
09-18-2018, 07:36 AM | #33 | |
| Re: Esc Quote:
Esc - Similar Threads | ||||
Which ESC Brake/Reverse Type Setting on my Mamba Max ESC? | b00st3d | Venom Creeper | 3 | 01-24-2010 04:34 PM |
RX pack & ESC, remove the red wire or leave the ESC switch off | BenW | Electronics | 5 | 02-23-2005 06:25 PM |
