Thread: Transmission/motor mounts steel verse delrin
Old 02-13-2007, 01:21 PM   #1
Default Transmission/motor mounts steel verse delrin
Just wondering the pros and cons between the two.
Rat1 is offline   Reply With Quote
Old 02-13-2007, 02:37 PM   #2
My guess would be weight & rust factor.
Rob $.02
FELIX is offline   Reply With Quote
Old 02-13-2007, 02:56 PM   #3
DaViolentOne's Avatar
Delrin would flex a LOT more than steel, I'd think...
DaViolentOne is offline   Reply With Quote
Old 02-13-2007, 03:03 PM   #4
Does the steel effect the magnetic field of the motor at all?
The reason I ask is because my tuber has a 1/8 inch steel skid on it. LOL I know it is over kill but I am trying to get a low CG. My servo plates are also made of 1/8 inch steel plate. I am just trying to offset the weight of the tubing by using heavier materials down low. I also plan to mount the shocks so the heaviest part is down low.
I do nto have a problem with removing the skid if need be but we do not have much in the form of Delrin or other plastic materials in my area. Would need to drive 50 miles just to get some.
Old 02-13-2007, 03:51 PM   #5
The steel should not effect the motors mag field just overall weight of the rig. Lot's of people use steel for skids and mounts on tubers and scalers. I use delrin for all kinds of parts and if you use a thick enough piece it is pretty sturdy.
racerx is offline   Reply With Quote
Old 02-13-2007, 04:36 PM   #6
i rather use steel its stronger
andrewmp6 is offline   Reply With Quote
