02-21-2020, 10:30 PM | #1 |
Newbie Join Date: Jan 2020 Location: US
| esc problems
my esc is getting power. there are lights on it. I plug it into a reciever and the lights start to flash like it's just waiting to pair. but then the reciever isn't getting power. what's going on. I assume it's my wiring, can anyone enlighten me? Sent from my SM-N960U using Tapatalk |
02-22-2020, 06:35 AM | #2 |
| Re: esc problems
did you bind it ? is everything plugged in the right way, what kind of ESC |
02-22-2020, 07:01 AM | #3 | |
| Re: esc problems Quote:
and it's a tazer mini brushed esc dyn4820wp yes everything is plugged in correctly. I know it's the esc because I can plug another esc into the reciever and it will power up and work normally, but wherever I plug this esc into any other receiver there are no power lights indicating it has power Sent from my SM-N960U using Tapatalk | |
02-22-2020, 07:15 AM | #4 |
| Re: esc problems
sounds like your internal bec took a dump to test that take a 7.4 2s battery and plug it in to the reciver and see if theres any change i had a brand new esc do the exsact same thing yesterday hooked it all up pluged it in went outside and got half way accrossed the porch and it died |
02-22-2020, 07:48 AM | #5 | |
02-22-2020, 08:07 AM | #6 |
| Re: esc problems
Calibrate your Tx and Rx.....not binding it
02-22-2020, 08:08 AM | #7 |
| Re: esc problems |
02-22-2020, 09:23 AM | #8 | |
when you say your getting beeps but no steering or throtle thats because the reciver isent reciving power if your reciver did have power your steering would still work the beeps are because the esc isent getting a signal from the controler the other esc your using you say it dose work so your reciver is good so its not the reciver your discribing a clasic battery eliminator circut failure to fix it buy a new bec you can get a cheap one for $2 or a realy good one for $20 and there are alot of in between units out there your discribing the same problem i had yesterday add a new bec and its all good again the bec going out is vary commin alot of people dont even use the built in bec and go stright to a external bec right out the box aftermarket bec can usualy handle more amps then the internal bec so if your using a high torque servo and or lights then your gona need a external bec Last edited by ferp420; 02-22-2020 at 09:40 AM. | |
02-22-2020, 08:48 PM | #9 |
| Re: esc problems |
02-23-2020, 12:41 PM | #10 |
| Re: esc problems |
esc problems - Similar Threads | ||||
possible esc problems? | j_the_pirate | Electronics | 5 | 05-16-2012 04:55 PM |
esc problems | nickd18 | Losi Micro-Rock Crawler | 19 | 12-01-2010 10:10 PM |
ESC problems | Warpiglmrc | Losi Mini-Rock Crawler | 6 | 01-30-2009 05:31 PM |
Problems with ESC??? | Rockmuncher | Electronics | 8 | 01-18-2007 10:14 AM |
