02-27-2020, 09:06 AM | #1 |
Newbie Join Date: Feb 2020 Location: Milford
| ESC Current Output Testing
Here is an interesting video from RC Review on YouTube. If nothing more to shed some light on how much current you can get out of some popular ESCs and BECs. https://www.youtube.com/watch?v=NYqDSJaSX4A |
02-27-2020, 09:31 AM | #2 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: ESC Current Output Testing
Interesting that the Mamba X put out more current than the Castle BEC. I'm glad I ditched my BEC when I installed my Mamba X into my Bomber.
02-27-2020, 06:42 PM | #3 |
Rock Crawler Join Date: Jan 2019 Location: Calgary
Not an accurate test at all. He should be measuring for voltage drop as well as current drawn. Also, more volts does NOT equal more current, his electrical theory is incorrect. If he did this test properly, I bet you'd see the Mamba X dropping more voltage over the BEC resulting in the higher current being drawn. The end result is that the power, or work being done is the same on both, but the BEC is more efficient over the Mamba X. |
02-27-2020, 08:22 PM | #4 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
| Re: ESC Current Output Testing I watched the video the day it came out, and it’s been bugging me ever since. I don’t claim to be great with electrical, but from my understanding, the bec (internal, or external) does not “put out” amperage. The load (servo in this case) draws the amperage. The draw should depend on physical resistance to servo, voltage being supplied, and built-in electrical demand of the servo. Amp rating of the bec (internal or not) just indicates what it can tolerate, and as electronics work, they get hot, heat increases resistance, resistance increases voltage drop, and lower voltage causes a drop in output (servo torque in this case). And I’m sure at some point those factors may cause esc to not work properly, or possibly fail altogether (internal bec). I’m probably wrong, but I really hope someone with real knowledge chimes in with a more informed explanation. Last edited by twade984; 02-29-2020 at 06:59 AM. |
02-27-2020, 09:25 PM | #5 | |
| Re: ESC Current Output Testing Quote:
Your understanding is superior to the author of this video in fact. My knowledge on the subject of electrical theory IS REAL knowledge btw Last edited by Xx Losungen xX; 02-27-2020 at 09:31 PM. | |
02-27-2020, 10:06 PM | #6 | |
maybe I'm just missing the point to the video. Maybe it's just meant to be a visual demonstration.. i don't know. I do enjoy his videos, and I'm not trying to talk shit. Just trying to understand better. Last edited by twade984; 02-29-2020 at 07:00 AM. Reason: Less talk, more tech. | |
02-28-2020, 01:04 AM | #7 |
Newbie Join Date: Jan 2018 Location: Prescott
I saw that video too, and was thinking that showing voltage drop along with the amps draw would have been more informative. The other thing I wonder about is how long can an ESC maintain the currant supply.
02-28-2020, 02:36 AM | #8 |
Quarry Creeper Join Date: Jun 2015 Location: France
Good video but missing a point ... knowing how much amps the BEC can deliver is great but when brown-out happen on the trail, it's rarely with just the servo running, but when both the servo and motor are taking their toll on the ESC ...
02-28-2020, 05:06 AM | #9 | |
02-28-2020, 05:10 AM | #10 | |
The way his video is produced, he seems to think that the BEC, esc etc. produces current and the higher the better, that's just completely false. | |
02-28-2020, 05:48 PM | #11 |
Rock Stacker Join Date: Mar 2019 Location: Canada
I don't understand why there would be a voltage drop with a switch mode regulator . That is what they are designed to do. Keep the voltage stable regardless of input voltage and current draw. I use a number of switch mode regulators in many designs and you can bet if the regulator does not maintain its voltage and up to its rated maximum current as specified in its data sheet then the whole lot goes back to the manufacturer as defective. If you feed a servo directly from a battery then there will be a voltage drop at the battery because it has internal resistance. Otherwise if I make a 5 amp switch mode regulator that is set to 6v for example. It puts out 6v at 1 amp at 2 amps or 5 amps. If it doesn't its either designed wrong or the manufacturer is lying in their datasheet and they will sure hear about it! It would have been nice to know what voltage each of the BECs were set at though since. I would hope that they are set to the same output level or its not much of a test. Last edited by Alka; 02-28-2020 at 06:49 PM. |
02-28-2020, 08:18 PM | #12 | |
02-28-2020, 09:16 PM | #13 |
Would love to see the source stating the BEC and mamba X are switching regs and what the specs are. Note that I only mention these two above. I already know the pro bec is a switching reg. What are the tolerances on the 1080s bec? Where are you guys buying switching regs with 0% tolerance? The best I've gotten my hands on are around 0.5%, built or bought. Crappy Chinese no name bulk ones can be upwards of 10%, have tested some as high as 20%. |
02-29-2020, 07:00 AM | #14 |
Pretty sure you will see switching regulators in all of these. I don't know why they would use a linear one since switch mode regulators are so cheap to make and produce much less heat and take up less board real estate for the same power output. I can provide no sources for this. I am only making a guess as to their designs. It would be like seeing a carburetor in a modern car. I am not saying there are perfect loss free devices but the output of a voltage regulator will be within tolerances that the manufacturer states. |
02-29-2020, 09:28 AM | #15 |
Quarry Creeper Join Date: Feb 2018 Location: East otis
So I've seen a few of his videos, which i enjoyed, but I've got one question. How does the amperage go up when the voltage goes up? Let's focus on the servo as just a dc motor. I am an electrician, so I know electrical theory and practice, at least in ac. Take a 3 phase ac motor, hook it up to 208v, and it draws say 32 amps. Take this same motor and hook it up to 480v, and it'll draw less then half of what it would on 208. Why? Well power equals amps times volts (P=IE). The motor will produce the same power ( watts) on either voltage, so increasing the volts decreases the amps. Take a dc motor, 3 phase (brushless) or single (brushed), and suddenly its the opposite? Seems like it from his videos on servo testing. Well how about our brushless motors? Take a 3500 kv motor, like a puller pro rated for 4s, run it on 2s and everything is cool and happy, throw it on 4s and things start to heat up. Now why is that? Seems like the motor is making more power (watts) which is more heat. In theory it should have the same wattage on 2s and 4s, which to me it doesnt seem to be the case right? Same with the servos, increase the voltage and it gets warmer faster, and also has more power. So what am I missing here? I don't know much on dc motors other then these rc motors, so I'm looking for someone to point me in the right direction here... Sent from my SM-G970U using Tapatalk |
02-29-2020, 10:48 AM | #16 | |
The servo (load) in this test is identical. If applied the same voltage across all tests, the load will draw the same current across all tests. In this test, the current is different across all tests, which means the voltage is as well, it's just a fact, actually it's a law. I'm very curious how it's being suggested that this very simple and basic law somehow does not apply here. It's quite obvious to me here that the voltage is NOT the same across all tests at FLA, otherwise FLA would be exactly the same. | |
02-29-2020, 11:31 AM | #17 | |||
It's exactly what it's designed to do. If I have an EMF of 12 volts and want to regulate it at 6 volts, I'm dropping 6 volts to do so. Quote:
The only way that would happen is to have an EMF of 6 volts, which would make your regulator pointless. Quote:
Except that what matters is what the actual observation says and not it's intended or designed output, and since it won't be a rise in voltage, it'll be a voltage DROP, would it not? | |||
02-29-2020, 11:40 AM | #18 | |
I really think we have our wires crossed on this one.. a voltage regulators output (buck) is lower than the voltage fed into it yes.. So if he is using a 28v power supply or a 10v battery what would knowing that help? Edit : reading back at your older posts I think I understand you want to see a comparison of efficiency . I apologize if i got you backwards.. we would also need to know the current draw at the source but this would be nice to know! Last edited by Alka; 02-29-2020 at 11:54 AM. | |
02-29-2020, 12:39 PM | #19 |
Is he not testing efficiency? Is he not concluding that higher observed amps are better? Can we not agree that given the simplest of all electrical laws that higher current implies a voltage drop? Do we not both know that a higher voltage equals a higher efficiency? Ie. Due to losses etc. If we are agreeing on those above, then we should be able to agree that yes, I am looking for the same test, efficiency but with accurate results? If we STILL agree, what are we missing? Voltage Drop! If you agree with my last sentence, wtf have we been talking about?! |
02-29-2020, 01:36 PM | #20 | |
Higher current does not imply a voltage drop . The current output can be fixed to a certain level by design and very simple circuitry. To get efficiency we would need to know watts at the source vs watts used by the servo. The difference would be watts wasted BY the bec. | |
ESC Current Output Testing - Similar Threads | ||||
ESC current | olfajarley | Electronics | 3 | 03-19-2015 01:21 AM |
Factory ESC/RX current and motor limits? | 89redranger | Losi Micro-Rock Crawler | 7 | 12-29-2012 11:33 AM |
Mamba Max Pro BEC Output Current? | Tommy R | Electronics | 4 | 05-06-2011 05:58 PM |
What does the Rated current on an ESC means? | Sasquatchbagger | Electronics | 1 | 02-27-2008 10:04 PM |
ESC BEC issue (current shortage) | tomik | Electronics | 4 | 07-04-2007 10:11 PM |
