03-20-2020, 09:33 AM | #1 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| Suspesnion Question
I am not sure if this is the right place to post this. If I use lighter oil or lighter springs the RC will lower under itself under its own weight and therefore have a lower COG at that point and time sitting there. My question? If my shocks are soft and I am side hilling won't the weight on the up hill shock transfer, unload the top shock but more load on the lower shock and cause a greater chance of tipping? |
03-20-2020, 10:57 AM | #2 |
| Re: Suspesnion Question
In short, yes. There are droop setups, that use a spring to pull the shock shaft back into the shock. This helps with the unloading. Sway bars help as does finding the right balance between spring stiffness and oil thickness. Last edited by lonleycreeper; 03-20-2020 at 11:00 AM. |
03-20-2020, 11:51 AM | #3 |
Yup, it's a balance between weight distribution on the truck, suspension link setup, shock mountings, shock oil and shock springs. You can always increase the shock oil weight to keep the shocks action under control and or put internal spacers inside the shock body to limit them from drooping out too much. Several factors to tune.
03-20-2020, 04:58 PM | #4 |
You need to understand that EVERYTHING in a suspension setup is a compromise. You improve one aspect of performance at the expense of another.
03-25-2020, 01:07 PM | #5 |
Newbie Join Date: Jan 2020 Location: Hudson Valley
| Re: Suspesnion Question |
03-25-2020, 02:05 PM | #6 |
Quarry Creeper Join Date: Mar 2020 Location: Las Vegas
I'll chime in with that not only do I agree with the other posters here, but there is also no "one" setting for all terrain. I find it very worth the while to experiment and make notes. This way you can set up for the next adventure that awaits! |
Suspesnion Question - Similar Threads | ||||
Mmp question and cc bec question. | Cchapman | Electronics | 6 | 12-24-2014 04:38 PM |
Tire foam question. WARNING!!! Noob question! | tokdl | Tires and Wheels | 6 | 05-07-2014 10:55 AM |
Drive way too fast question and front locker question. | Mr.JayDeeM | Axial AX-10 Scorpion | 15 | 02-07-2012 09:19 AM |
clearance question and articulation question | axialnut | Newbie General | 17 | 09-24-2010 09:55 PM |
Simplefied question for pervious question. | Mudsy | Tamiya Clod Buster | 2 | 05-03-2009 09:59 AM |
