06-24-2004, 05:00 PM | #101 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
| Re: PROJECT BD
I always thought that the jumbo's rim has a bigger diameter than a standard maxx rim. Are they the same diameter? Anyway, that is an awesome project, It'll be even better with a tube frame. |
06-24-2004, 05:10 PM | #102 |
Quarry Creeper Join Date: Jan 2004 Location: CSU, CO
| Re: PROJECT BD
Sounds interesting, I can’t wait to see some progress so I can steal your ideas for my X-Factor axled project.
06-25-2004, 08:41 AM | #103 |
I wanna be Dave Join Date: Jan 2004
| Re: PROJECT BD
Griz, You are dead meat now!!!!!! Customcrawler, the diameters are so close, the IMEX wheel, tires and Maxx wheels, tires are all interchangeable. I ran Jumbos on RPM maxx wheels for quite some time. No tube frames for me, however, I will have a small cage that bolts to the chasis for this project. Neo, Stealing is good. |
06-25-2004, 09:46 AM | #104 | |
| Re: PROJECT BD Quote:
Seriously though, arent you worried that with the width of the xfactor axles and the height of the tires you might have trouble with hanging on the diffs? Wouldnt using the TXT axles and being a little narrower be a better combination? | |
06-25-2004, 11:57 AM | #105 |
| Re: PROJECT BD
Yes Griz. To most amature builders and Clod drivers, I can see why you might think that. However, I have a few tricks up my sleeve. Keep in mind that, even the Digler, being as big as it is, is only slightly wider than a clod with wideners. Also, if the Krocks are a true 7 inches, then I will only lose .5 inch compared to the Kongs. When I ran the BFT's on the Digler, it did very well but I had to be a little more careful about the lines I took. I'm hoping to get this new truck geared low enough that I'll have ultimate control for tire placement. |
06-26-2004, 02:31 PM | #106 |
RCC Addict Join Date: Apr 2004 Location: 5280
| Re: PROJECT BD
Jeez Pete, make up your mind. And give me those TXT axles :P Hey man you need to give me a call... I got some ideas that when applied will make the clods bow down to the shaft driven trucks Anyways...keep up the good work. BD is looking/sounding nice.
06-28-2004, 10:39 AM | #107 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
No, really it was the was he set it up, as tall as he could get it, almost no steering, and extremly stiff shocks with no oil in them. I think you all could learn something from him | |
07-01-2004, 05:13 AM | #108 |
Newbie Join Date: Jul 2004
| Re: PROJECT BD
Great Project!! Any info on how you adjust the ride height? Thanks |
07-01-2004, 11:03 PM | #109 |
Quarry Creeper Join Date: Apr 2004 Location: Louisiana
| Re: PROJECT BD
Updates!!! How much belly clearance do you have in the slammed position????? |
07-02-2004, 09:41 AM | #110 |
Quarry Creeper Join Date: May 2004 Location: Neosho
| Re: PROJECT BD
WE NEED PICS!!! |
07-02-2004, 09:44 AM | #111 |
| Re: PROJECT BD
Not yet. By next week, I'll have some updated pics with the Xfactor axles, caged body, etc. It'll probably be running at 100% by late next week.
07-02-2004, 11:10 AM | #112 | |
You couldnt use the TXT axles could you! Ill ask again, what is the belly clearance in the slammed position? | |
07-02-2004, 11:21 AM | #113 |
| Re: PROJECT BD
I'll still have a TXT based truck though. So I'm not a total TRADER. I think the clearance is about 3 to 3.5 inches, slammed! |
