07-07-2021, 01:48 PM | #21 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
| Re: Element Enduro Builder's Kit... 2
I got the kit a couple years back and the panhard bar mount/shock tower were a week point so the GKS could be good up grade. The high link clearance links are a good up grade. The link ends sucked in the kit I got, they would pull out and and the plastic pivot balls didn't last. Delrin is a hard plastic, may they will work? Hopefully the links ends themselves are better then they had been. They still need to do something about their axles though. |
07-07-2021, 01:48 PM | #22 |
Pebble Pounder Join Date: Nov 2009 Location: Newmanstown, PA
Potentially dumb question - the GKS panhard mount: will it fit the stock chassis rails included with the kit, or do holes need to be drilled?
07-07-2021, 01:50 PM | #23 | |
| Re: Element Enduro Builder's Kit... 2 Quote:
All the newer post Gatekeeper releases have the updated rails I believe. | |
07-07-2021, 01:51 PM | #24 |
| Re: Element Enduro Builder's Kit... 2 |
07-07-2021, 08:04 PM | #25 | |
Will have to get into my kit box to double check but so far the manuals for the builders kit vers. 1, and gatekeeper kit have different part numbers for the rails. So unless they are still making two separate rails, and haven't updated the manuals, I'd have to drill holes for the GKS panhard. | |
07-07-2021, 08:53 PM | #26 |
07-08-2021, 06:10 AM | #27 |
Newbie Join Date: Nov 2017 Location: Greenville
hmm..I wonder if my Sendero HD has the holes for the GKS panhard mount, guess I'll need to check when I get home today
07-08-2021, 11:34 AM | #28 |
07-08-2021, 01:54 PM | #29 |
| Re: Element Enduro Builder's Kit... 2 It looks like my builders kit does have the necessary holes on the frame rail. I’m guessing your truck should too. It’d make no sense for them to be making two different rail sets anymore.
07-09-2021, 10:17 AM | #30 |
| Re: Element Enduro Builder's Kit... 2 https://www.associatedelectrics.com/...uilders_Kit_2/ $10 more MAP price compared to the original kit. -__- |
07-09-2021, 02:30 PM | #31 | |
Newbie Join Date: Mar 2021 Location: U.S.
07-09-2021, 07:51 PM | #32 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
Also worth noting, it does not appear to include the machined trans gears. Personally, I can live with that. I think this is a really cool option. I’ll be curious to see if the original kit is discontinued. Sent from my iPhone using Tapatalk |
07-10-2021, 07:27 AM | #33 |
07-10-2021, 11:36 AM | #34 |
Quarry Creeper Join Date: Jan 2020 Location: MIAMI
I was looking fwd to this, but looking at the specs, kind'a disappointed. Upgrades: 1) High clearance links . 2) Aluminum Panhard Rod mount. Downgrades: 1) Plastic end caps on shocks instead of aluminum. 2) Only 2 gear options included instead of 3 as original Builder's kit. Tossup: 1) Delrin pivot balls instead of metal. Not sure there's that much to get excited about here |
07-10-2021, 11:41 AM | #35 | |
Why do you feel plastic caps are inferior? Sent from my iPhone using Tapatalk | |
07-10-2021, 12:42 PM | #36 |
Quarry Creeper Join Date: Jul 2020 Location: Lincoln
This release appears to be the Factory Team version, similar to the AE’s racing kits. Not really innovative, but good solid slider to start with. Sent from my iPhone using Tapatalk |
07-10-2021, 04:03 PM | #37 |
| Re: Element Enduro Builder's Kit... 2 All else being equal the alu caps ends are more durable, dimensionally stable and will not distort / strip threads over time as easily. If you never open your shocks to replace or change the shock oil, it might not be an issue, but I prefer aluminum over thermoplastic any day of the week.
07-13-2021, 02:07 AM | #38 |
Quarry Creeper Join Date: Nov 2017 Location: Ulaanbaatar
07-13-2021, 04:57 AM | #39 |
Sorry Element, but I'm not getting one until its fitted with proper sized pinion bearings, preferably with a high pinion gearset and housing to match.
07-13-2021, 07:14 AM | #40 |
| Re: Element Enduro Builder's Kit... 2 It really is amazing for the amount of popularity that there is no aftermarket upgrades for the axle housings. The first company that makes an Element housing with larger pinion bearings is going to sell a boat load of them.
Element Enduro Builder's Kit... 2 - Similar Threads | ||||
Soze finally gets around to the Element Enduro Builder's Kit | soze | Element RC 1/10 Enduro Trail Truck Sendero | 34 | 11-05-2021 10:33 AM |
Dabbler does an Enduro builder's kit | johnnyluv | Element RC 1/10 Enduro Trail Truck Sendero | 3 | 04-03-2020 11:30 AM |
New Enduro Trail Truck Builder's Kit - In Stock! | RPP Hobby | RPP Hobby | 0 | 07-10-2019 11:27 AM |
Pre-Order Now - New Enduro Trail Truck Builder's Kit | RPP Hobby | RPP Hobby | 0 | 06-06-2019 07:06 PM |
