07-29-2012, 08:25 PM | #1 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Battery size for g6?
I may be doing a g6 event, but I have never done one before, so I have a 2s rig and I'm not sure what size batteries will be needed for an event. I'm assuming people change batteries between stages, but how long is a typical stage and how many stages are typically done at an event?
07-29-2012, 08:59 PM | #2 |
Rock Crawler Join Date: May 2009 Location: branchville
| Re: Battery size for g6?
i can normally do 2 1 hour stages with bashing afterwards with a 5000mah 2s in my honcho
07-29-2012, 09:02 PM | #3 |
RCC Addict Join Date: Mar 2009 Location: Across the street from Folsom Prison
Whatever you have make sure you have spares if your doing a recon g6 Sent from my SPH-D710 using Tapatalk 2 |
07-29-2012, 09:46 PM | #4 |
| Re: Battery size for g6? |
07-29-2012, 10:20 PM | #5 |
Pebble Pounder Join Date: Feb 2009 Location: PA
whats a good size for non-lipo. water hates the lipo. what should i run.
07-29-2012, 10:25 PM | #6 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
We did 525 gates at malvado. I used 6-1300's for the whole event. 6.5lb honcho, 35t w lots of timing and faster gearing. Your best test is go out and time your runtimes. |
07-29-2012, 10:26 PM | #7 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
I carry 5 1800 3s. I usually use 3 1/2 for a day g6'n. Its better to have em and not need em than to need em and not have em |
07-30-2012, 05:23 AM | #8 |
07-30-2012, 05:36 AM | #9 |
Quarry Creeper Join Date: Sep 2008 Location: Australia
07-30-2012, 06:32 AM | #10 |
Rock Crawler Join Date: Oct 2011 Location: Warren
07-30-2012, 07:20 AM | #11 |
I wanna be Dave Join Date: Nov 2007 Location: roseville
lipo is the way to go axialfest i ran 500 gates with 2 2200 lipos.
07-30-2012, 09:24 AM | #12 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
I run with a group of guys alot and our trail runs last from 1-2 1/2 hours. Our lipos are all 5000mah or over 2 cell packs.. We are gonna be running the superlift g6 in September, I'm bringing all my packs.. They are all 2s, 3 of them are over 5400mah...I'm thinking I'll be able to run 1 pack for the first stage and 1 for the 2nd.. My truck weighs close to 8-9 pounds( never weighed it) but I can run over 2 1/2 hrs on a pack and not get close to my cutoff...
07-30-2012, 09:33 AM | #13 | |
| Re: Battery size for g6? Quote:
07-30-2012, 10:15 AM | #14 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
I ran my Wraith on 2S at Axialfest with a 3300kV Pro4 and had to swap packs after 300ish trail markers. Both packs were 5200's, in total I used about 8500mAh for that 500 marker stage, took just over 3 1/2 hours.
07-30-2012, 11:10 AM | #15 | |
Battery size for g6? - Similar Threads | ||||
Max battery size | motas | Axial SCX-10 | 6 | 04-19-2011 05:29 PM |
battery size | davosfam | Newbie General | 5 | 07-07-2010 07:22 PM |
Battery Size | Alan | Team Losi Comp Crawler | 7 | 01-03-2010 07:57 PM |
which battery size? | pontiacfreak | Electronics | 2 | 12-16-2009 12:23 PM |
Battery size... | BigJay | Electronics | 2 | 07-24-2005 05:25 AM |
