01-14-2013, 11:37 AM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: SLC
| link lengths, setup, & wheelbase
I know everyone has their own ideas of what is perfect...but i'm curious of there is a consensus regarding "ideals" I ran into a slight problem when I built my H3T- xcab. I had it setup to be around 11.5''. However, to get the body to fit, the wheels to fit and all that I ended up having to push the front out a ways. I will be using 100mm links (could even use 106 if I run larger tires) The problem is that after already building the tube bed, it means I'm running roughly a 70-75mm rear lower link. I am scared that's going to be too short. That also only puts me at ~ 11.25'' wb for a Class 2. On my Class 1 crew cab Hilux I ran 98mm front and I dont' recall the rear (I think around 91mm) That works fine, but I worry the shorter links on the H3 are going to be a problem. Does anyone see a problem with that? Has anyone ran something similiar? What do you "shoot" for when you build? |
01-16-2013, 12:17 PM | #2 |
| Re: link lengths, setup, & wheelbase
Noone has tried links that short? That worries me |
01-16-2013, 01:32 PM | #3 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
I don't see a problem with it. I generally try to use shorter links up front and the longer ones in the rear for a 40/60 weight bias, but that's just me. I like having more weight towards the front on my builds, but I can totally understand your predicament.
01-16-2013, 04:46 PM | #4 |
Well that's good. I'm hoping that with the Pitbulls you sent me I will be able to push the back a little further out. I have been measuring with Iroks, and at 4.65'' I think they are just too big for this build....so I'm hoping with the different tires I can get another 5-10mm out of the back...once I have them I will be able to mock them up and see how they sit in relation to the tube bed.
link lengths, setup, & wheelbase - Similar Threads | ||||
4-link and link lengths questions | T DAWGv12 | Axial SCX-10 | 5 | 11-27-2010 11:17 AM |
upper link lengths for SCX10 with stock four link | oscodawave | Axial SCX-10 | 4 | 11-19-2010 08:23 PM |
Looking for link lengths for 4 link on the Honcho | Skeeno | Axial SCX-10 | 5 | 12-20-2009 08:34 PM |
Stretching Wheelbase-front and back lengths | Sasquatchbagger | HPI Wheely King | 3 | 11-29-2007 11:55 AM |
SW2 Link Lengths and Setup options ???? | ScaleHobbies | Tamiya TLT Crawlers | 13 | 08-18-2006 05:19 AM |
