03-11-2015, 09:53 AM | #81 |
Quarry Creeper Join Date: Nov 2013 Location: canada
| Re: New Bright chassis advice
With The Motor up front. And servo Gear on the chassis. that is bound to happen. I'm thinking of combating with Two Batts mounted on either side of frame rails on makeshift rock sliders. And maybe a nice metal bumper and tire mounted |
03-11-2015, 05:02 PM | #82 | |
Pebble Pounder Join Date: Oct 2014 Location: Santa Barbara
| Re: New Bright chassis advice Quote:
swyped from my M8 with root privileges | |
03-25-2015, 07:19 PM | #83 |
Small update, installed much needed lighting over the bench top. Cleaned up and permanently wired all the electrical. Put the bec in the receiver box with a toggle to kill the power. The roof and bumper light bars are on a toggle, have a spare toggle for I don't know what.....lol. installed 90mm shafts on the rear King shocks along with a swaybar. Weighted the rear wheels, she runs pretty stable now. Bec is set to 7.4v them lights be bright as...... I'm thinking I need some metal axles........$$$$...... swyped from my M8 with root privileges |
03-25-2015, 09:20 PM | #84 |
Looks good. me jelous. only hting really holding me bacdk from moutning with 2.2's is the stock front bumper |
03-25-2015, 09:59 PM | #85 | |
03-27-2015, 10:36 AM | #86 |
What type of driveshaft are u running to ur axles? how do u like the 90mm shafts on the kings? Looks Great man. |
03-27-2015, 11:02 PM | #87 | |
03-28-2015, 02:54 PM | #88 |
Thanx man. I will check out the junfac's, U using the 155mm ones? You got any running videos? Show off that rig |
03-28-2015, 05:20 PM | #89 |
155mm and a stock length for scx10 in the rear. I have video but not sure how to download it without posting it on YouTube. Lol swyped from my M8 with root privileges |
03-28-2015, 06:18 PM | #90 |
| Re: New Bright chassis advice |
04-02-2015, 05:10 PM | #91 |
Does anybody have any experience with Hot Racing axels? I can get front and rear complete axels for less then one Currie. swyped from my M8 with root privileges |
04-26-2015, 10:02 PM | #92 |
07-04-2015, 02:32 PM | #93 |
Are the these bodies the same as the ones with the interior? If so I was thinking of getting one for a spare. Will the interior bolt into to this body? All my mounting points are on my interior, in theory I should just be able to swap the body. For $35 should get a couple, the interior should outlast the body. swyped from my M8 with root privileges |
07-04-2015, 03:45 PM | #94 |
Quarry Creeper Join Date: Jun 2008 Location: San Antonio
yes and no. I bought two thinking it was, but the material is different. Not plastic, but some sort of plastic-type. No interior at all, but with some work you can get an interior to fit.
07-05-2015, 12:34 AM | #95 |
07-05-2015, 08:22 AM | #96 |
07-05-2015, 10:45 AM | #97 | |
| Re: New Bright chassis advice Quote: swyped from my M8 with root privileges | |
07-05-2015, 01:04 PM | #98 |
You still have to modify it somewhat to make it fit. I had to cut off the back tray, and figure out a way to mount the interior in the back. The front of the interior will mount into the holes already molded into the body. The roof, I had to cut on the body to make the back fit. If you look closely, you can see the two screws that I used to hold the two together. I can take some more pics if it will help.
07-05-2015, 08:14 PM | #99 | |
11-01-2015, 10:35 PM | #100 |
So I got metal axles for the new bright They ended up in a new build Witch got put on the back burner for this build Stumble on race730 YouTube channel and was inspired to build a Willys...... Should have it running next week! swyped from my M8 with root privileges |
New Bright chassis advice - Similar Threads | ||||
need chassis advice... | mhflies | Losi Mini-Rock Crawler | 6 | 06-26-2012 11:06 AM |
wanting a new chassis need advice | idk | Losi Micro-Rock Crawler | 5 | 03-05-2012 10:29 PM |
New Bright Jeep Wrangler 4-Door, 13" WB Build... Looking for advice and guidance. | MrNice Guy | Axial SCX-10 | 2 | 06-02-2011 01:36 PM |
Looking for a pinch chassis... Or advice on a BWD chassis | DSchulten88 | Losi Micro-Rock Crawler | 5 | 12-24-2010 11:34 PM |
