01-24-2015, 09:22 AM | #1 |
Pebble Pounder Join Date: Oct 2014 Location: Santa Barbara
| New Bright chassis advice
Hi all.. I am trying my hand at building a rig using a New Bright body. Lots of inspiration here. I'm debating between GCM cross canyon or TSS chassis using the forward mounted rc4wd R2 trans. I've seen lots of info on GCM, looks like a great setup. I have yet to see the TSS set up. Anybody here use this setup? And maybe posts some pics? I would greatly appreciate it. Here are a few pics of what I have so far. Don't have much spare time so it is slow going. swyped from my M8 with root privileges Last edited by robbo; 01-24-2015 at 10:07 AM. |
01-24-2015, 01:41 PM | #2 |
Rock Crawler Join Date: Oct 2012 Location: Vermont
| Re: New Bright chassis advice
I have a couple 4-door JKs and a China 2-door. The China JK is my next build when I'm done building my prerunner and I'll definitely be using GCM. Can't beat their packages with links, motor mount, transfer case, and chassis all ready to go. Even their own axles look pretty good.
01-24-2015, 02:07 PM | #3 |
Rock Crawler Join Date: Jun 2010 Location: KCRC
I've used the GCM on the NB and have been very happy with it. No experience with the Tcs. Might also check out Dinky RC' s divorce kit and cantilever rear suspension, it would work good as well.
01-24-2015, 03:41 PM | #4 |
Yes the GCM is the whole package for sure and that is the way I'm leaning. As far as the links, I'm set on titanium, VP has a good selection of different sizes and with the combination of short and longer rod ends I believe I can make it work. Although the expensive route. The TSS utilizing the R2 trans and getting rid of some bulk is intriguing. I would still like to see the TSS setup to make up my mind. The the cantilever setup is pretty cool! Thanks for the comments guys! swyped from my M8 with root privileges |
01-25-2015, 12:12 PM | #5 |
Worked on the interior, had some trouble with Tamiya paint, Krylon fusion bonded great. Touchup time. swyped from my M8 with root privileges |
01-25-2015, 04:20 PM | #6 |
Quarry Creeper Join Date: Nov 2013 Location: canada
what base are u using scx10?
01-25-2015, 05:58 PM | #7 |
Yes, scx10 . Just trying to makeup my mind on chassis swyped from my M8 with root privileges |
01-25-2015, 08:12 PM | #8 |
are u doing the whole motor forward thing or just the chassis?
01-25-2015, 09:16 PM | #9 |
Motor forward using either GCM or TSS chassis, GCM uses Axial trans and TSS uses rc4wd R2 trans swyped from my M8 with root privileges |
01-26-2015, 10:52 PM | #10 |
Rock Crawler Join Date: Mar 2011 Location: USA
Toyzuki on here is making a new chassis ,,with all the geometry improvements ,,Can find him in the vendors section ,,It looks pretty sweet |
01-27-2015, 09:16 AM | #11 |
i'm soon putting together my thread/build. I do not know what to do for a chassis yet. I think i'm going scx10 base. was gonna use a cheaper redcat Everest 10 and slowly upgrade it, but I think scx10 would be better. either way will all the guts of the scx10 fit either of those chassis plates, if I just bought the plates no the 300$ kit |
01-27-2015, 09:21 AM | #12 |
are ur lights setup to function in the rear with braking?
01-27-2015, 09:50 AM | #13 |
what did u use to fill in the fender flare gaps?, just body fill?
01-27-2015, 01:28 PM | #14 |
| Re: New Bright chassis advice |
01-27-2015, 01:30 PM | #15 | |
| Re: New Bright chassis advice Quote:
I'm just going with the simple lighting, no working brake lights. I used auto bondo to fill the holes. swyped from my M8 with root privileges Last edited by robbo; 01-27-2015 at 01:33 PM. | |
01-27-2015, 02:28 PM | #16 |
I might pick up the gcm chassic basic combo and some scx10 axles and a tranny to start my build thanx for info keep posting updates |
01-28-2015, 12:18 AM | #17 |
Well I took the plunge and ordered the GCM basic Cross Canyon kit. It seems to be the proven platform and best bang for the dollar. Next will be ti links..... swyped from my M8 with root privileges |
01-28-2015, 08:17 AM | #18 |
Nice. Cant wait to see what you do with it all. Are you sticking with stock scx10 shocks? |
01-28-2015, 04:02 PM | #19 |
01-29-2015, 10:32 AM | #20 |
What did u do for interior, just tape off and spray? or did u acutally get itn here with a small brush? Thanx man |
New Bright chassis advice - Similar Threads | ||||
need chassis advice... | mhflies | Losi Mini-Rock Crawler | 6 | 06-26-2012 11:06 AM |
wanting a new chassis need advice | idk | Losi Micro-Rock Crawler | 5 | 03-05-2012 10:29 PM |
New Bright Jeep Wrangler 4-Door, 13" WB Build... Looking for advice and guidance. | MrNice Guy | Axial SCX-10 | 2 | 06-02-2011 01:36 PM |
Looking for a pinch chassis... Or advice on a BWD chassis | DSchulten88 | Losi Micro-Rock Crawler | 5 | 12-24-2010 11:34 PM |
