04-04-2009, 04:16 PM | #21 |
RCC Addict Join Date: Dec 2007 Location: Chuck Chuck Chuckin Rocks.
Yes! Interested. Keep me posted. Thanks JC |
04-05-2009, 09:24 AM | #22 |
Newbie Join Date: May 2006 Location: Shawnee
Interested....which it wasn't so far out though.
04-05-2009, 05:59 PM | #23 |
Rock Crawler Join Date: May 2006 Location: Georgia
John can you give me a quote for some packs to run in an E-Revo? Im using 2 8.4 4000mah packs now. I would like to stay close to the same volt/mah that I have now.
04-06-2009, 03:14 AM | #24 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
I would be highly interested in two 3s pyramid packs ready with deans and taps but I cannot seem to find a way to order them through your site? Darn how did I miss this thread.
04-06-2009, 05:38 AM | #25 |
I will only have them for order when they hit the shores. TLTryan- however many cells you want, multiply times $10 for your pack cost. 6 cells would be close to the same of what you have, constructed 3s2p. |
04-09-2009, 07:41 PM | #26 |
Rock Crawler Join Date: Feb 2007 Location: CoMo...Kickin it with Holmes Hobbies
Hey JRH can they build some packs in series(or is it parallel), so i can have a 4600 3s pack.
04-09-2009, 08:02 PM | #27 |
Yeah, that is easy. My bike packs will be 6s2p, and on the larger packs we can get a plastic hard case.
04-09-2009, 08:16 PM | #28 |
sweet, so when you get them in. im wanting 2 3s 4600 packs, and 2 2s 2300 packs, and maybe a 3s 2300 pack.
05-06-2009, 12:24 AM | #29 |
Quarry Creeper Join Date: Jan 2007 Location: Alberta, Canada
Definately interested in a 10S1P pack....probably two at these prices...maybe 3! And a couple 2S1P packs...maybe 3. What's an XH-style balance connector? Is this the same as the Cellpro 10S connector? I can wait...going to be a while before the helicopter is assembled anyways. Last edited by DKNguyen; 05-06-2009 at 12:29 AM. |
05-06-2009, 06:25 AM | #30 |
They are in customs right now. Not sure what the cellpro uses.
05-06-2009, 01:48 PM | #31 | |
Rock Crawler Join Date: Jun 2006 Location: LOMPOC
It is the same as the align tap. These are the JSt xh taps. Go to maxamps and look at there pics and you will see the align ones. | |
05-06-2009, 03:47 PM | #32 |
I see. THe XH 5S connector does not look like the CellPro 10S connector then. Dang.
08-24-2009, 09:43 AM | #33 |
Just got them in as loose cells. I decided to not get them built up in packs since it was taking so long to get it done. I may offer pack building services later, if I have time. http://holmeshobbies.com/product.php...5&cat=0&page=1 |
08-24-2009, 05:56 PM | #34 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
I have not messed with these before but they look to be great for a rock racer . I was thinking of a four cell pack (two on each side). A few questions - first I know that they take a special charger to charge them - second, can these be wired up just like any Nimh battery? - anything special that has to be done to them to make them work properly. |
08-24-2009, 07:55 PM | #35 |
These do need a LiFe (a123) charger, but you can use a 12v lead acid setting for 4s packs. An occasional balance is a good idea. Otherwise they can be wired up like any other battery. A low voltage cutoff is good to have to keep them running strong for years. If you don't use a LVC it can reduce cell life. |
08-24-2009, 09:34 PM | #36 |
Quarry Creeper Join Date: Apr 2009 Location: Israel
I've been running these in my rig for the last 6 months. came from a Devolt pack. I wired up three cells to make 9.9v in a triangle shape they work great but are a bit high. Good cells IMO. |
08-25-2009, 08:13 AM | #37 |
Rock Crawler Join Date: Jan 2006 Location: SUPERMOTO heaven
thanks for offering these as loose cells |
08-25-2009, 08:32 AM | #38 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
If i were to make a 3s should i just solder wires directly to the cells? Any danger in doing it? Im not bad at soldering but may need a better iron for this application.
08-25-2009, 08:50 AM | #39 | |
I use a big pistol grip 140 Watt one I bought from lowes. It heats up the end where you solder but does it quick enough that it doesn't overheat the cell. | |
08-25-2009, 08:54 AM | #40 |
Thats the style i have. Half trigger pull is less wattage.
