11-24-2019, 01:48 AM | #381 |
Quarry Creeper Join Date: Nov 2005 Location: Italy
| Re: Puller Pro Brushless 4 pole Rock Crawler motors- Lay down the Power!
Hallo John, I'd like two suggestions from you: - Revolver snubnose 1800kv, driven with MicroX at 3s. Used on Capra. Is there a setting or other suggestion to lower the noise? I love the output, torque control and powerband, but the "alien"noise is a bit too much and gets annoying after a while. This is not my first outrunner, I'm happily using 2836 sized 1500kv on CFX-W and the noise level is much lower, with MicroX. - Puller Pro Stubby 2200kv, driven with MicroX at 3s. Used on Capra, Ascender, Scx2. Is there a way to improve the drag brake holding power? On both setups I'm using the aux wire for crawler-racer, with radio knobble 0 to 100% drag live setting. Thanks in advance |
11-24-2019, 01:35 PM | #382 | |
| Re: Puller Pro Brushless 4 pole Rock Crawler motors- Lay down the Power! Quote:
You can increase drag brake with more geardown. The "hold" of a motor is at direct odds with the startup smoothness, however. If you want a motor to hold with zero rolling but geardown can't get you there, its either using a larger motor that is smooth starting (puller standard), or use a motor that is not so smooth starting but has strong hold force (roc412) | |
11-24-2019, 02:02 PM | #383 |
Thanks John So for the Revolver would be benefit to change the esc to something else? I like the micro x for the size and aux cable, but if noise can be improved i can experiment... If i understood correctly, on page 17 you were talking about dithered and 18k frequencies which are more silent, and those are available only on Ble, correct? And what about Sidewinder 4, will it offer any benefit over the micro and Ble? I read you were saying the cryo hardware is different from previous escs, but will it make any difference in frequencies smoothness and noise? Thanks again |
01-11-2020, 05:32 PM | #384 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
Any estimate date to get back in stock 3500kv motor?
01-12-2020, 03:32 AM | #385 |
Also, You 3500k PP in my wraith with 87/14 and stock diff ratio will hold on every step with Mamba X esc? Thanks |
02-05-2020, 05:30 PM | #386 |
I see the new Puller Pro V2's are now listed on your site. What sort of changes have been made, and how does that affect driveability from the previous version? I only noticed the rotor diameter has been increased from 17.5 to 18mm. Will there be any other kv's available, or just 2700 and 3500?
02-06-2020, 10:18 AM | #387 |
We will have 2200 in standard, and 1200 and 1800 added to stubby. The changes include adjustable timing , better reverse operation, and better drag brake. The rotor change helped drag without hurting startup enough to matter. We can offer tuning rotors for people that want that original feel, although I dont think anyone will be bothered at all by the change.
02-06-2020, 10:25 AM | #388 | |
02-06-2020, 10:35 AM | #389 |
Indeed
02-06-2020, 11:00 AM | #390 |
I've updated the site to include details of improvement now. Thanks for the questions. I'll be making a vid outlining the construction tomorrow.
02-06-2020, 11:02 AM | #391 |
Newbie Join Date: Oct 2019 Location: Iceland
| Re: Puller Pro Brushless 4 pole Rock Crawler motors- Lay down the Power! |
02-06-2020, 11:03 AM | #392 |
And here she is! I was torn on going back to all black, or leaving some remachined fanciness. You can see that fancy looks won this time |
02-06-2020, 11:29 AM | #393 |
| Re: Puller Pro Brushless 4 pole Rock Crawler motors- Lay down the Power! I love the remachined look on almost anything. And it gives your motors a more premium look than all black motors IMO. I'm glad you made this choice. |
02-06-2020, 11:54 AM | #394 |
02-06-2020, 12:12 PM | #395 |
I don't need lower price but I appreciate the effort, thank you. It's not question of price, I was interested for lower kV motor and nobody mentioned that lower kV Stubbys are on the way. I'll throw Axe 2200 to another rig, install Stubby with 11T pinion and I hope it will be so slow and smooth as I want... Damn, so close... |
02-06-2020, 12:53 PM | #396 |
The phone guys arent always in the loop on my new products. There is always something new coming.
02-14-2020, 08:57 PM | #397 |
Newbie Join Date: Aug 2018 Location: Philippines
Hi JRH. I currently have a micro x and revolver v2 1800 on my Enduro. Fantastic start up and smooth all thru out. Downhill control is amazing.... bunch of guys in my local site are now considering switching after what they have seen lol. I just finished building a VS410 pro. I'm set on a Mamba X but still undecided on the motor. I'm thinking of going w/ a Puller Pro or Revolver. This will be used mostly in slow crawling w/ wheel speed just enough to get out of situations and some light trailing. What can you recommend? Downhill control is must have lol TIA ***Just realized i may have posted in the wrong thread. Sorry about that Last edited by Rmendz; 02-14-2020 at 09:02 PM. |
02-15-2020, 08:36 AM | #398 |
You may have to shave the skid a touch for the v2, but I would personally run a 2200 v2 standard puller. LOTS of brake and downhill control when combined with a mamba X. Maybe not quite as much as a revolver, but it runs quiet and has higher efficiency and wheelspeed. 2700kv is also a great speed. Maybe a bit fast if you aren't looking for slight jumping ability. |
02-15-2020, 02:41 PM | #399 |
Newbie Join Date: Feb 2020 Location: Mililani
What would be the best esc for the puller 500? Sent from my iPhone using Tapatalk |
02-15-2020, 06:31 PM | #400 | |
Puller Pro Brushless 4 pole Rock Crawler motors- Lay down the Power! - Similar Threads | ||||
Holmes Hobbies 2 pole vs 4 pole brushless | CoolRunning | Electronics | 1 | 02-13-2017 08:32 AM |
