Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: Affordable self made lockouts.
Old 04-01-2009, 02:55 PM   #21
will be trying it this weekend!!!
thanks for the info fellas
chris akhay is offline   Reply With Quote
Old 04-04-2009, 10:40 AM   #22
I managed to break one of my lockouts. It was made out of the end of the pvc that was threaded. My crawler took a fall off of a ledge and the tire rolled down the hill.:-( Will be making a new lockout, and some spares today.
evileddy420 is offline   Reply With Quote
Old 04-13-2009, 05:01 PM   #23
Default shaft length?
did u have to get a longer shaft or use the 2 peice shaft???
Jstalker is offline   Reply With Quote
Old 04-14-2009, 11:45 AM   #24
I used the stock axle and stub shaft. cvds would fit right in as well.
Old 04-14-2009, 05:57 PM   #25
Thumbs up
thanks evileddy not sure if iam going to do this or buy the fancy chrome alloy ones with the one piece shaft
thanx again
Old 04-14-2009, 06:07 PM   #26
im new to this wheely king stuff, what do these lockouts do?
traxxas4fun is offline   Reply With Quote
Old 04-23-2009, 02:49 PM   #27
They eliminate the steering knuckle, linkages, and extra more breakable parts. One piece axles also help to eliminate some more of the drivetrain slop.
aj6502 is offline   Reply With Quote
Old 05-15-2009, 01:11 PM   #28
Great mod! I will be doing this to my wheely king as soon as I get time.This web site is great.
rcalhoun is offline   Reply With Quote
Old 05-18-2009, 07:42 PM   #29
damn, thats pretty slick' great write up
bigjay1973 is offline   Reply With Quote
Old 05-23-2009, 08:44 PM   #30
I joined the Band!
Im with him...I understand the concept, but since I dont have a Wheely King as of yet, Im not sure if I understand where these are located. Front or rear? Front makes no sense to me since the truck wouldnt be able to turn if you eliminate the knuckles. Using it on the rear does make sense, but at that point what doesnt make sense is why HPI would make the rear have knuckles without ever intending them to turn?
devestator_x is offline   Reply With Quote
Old 05-24-2009, 10:21 PM   #31
They give them knuckles on the rear so you could have the option of 4wheel stear.
grizz is offline   Reply With Quote
Old 06-04-2009, 10:05 PM   #32
This is cool,so i tried it with aluminum round stock,I made mine a little diffrent,I extended the tube all the way to the end bearing,I machined an aluminum support ring for the end to take up the slack and make it tougher
I was affraid that whitout the support ring it may bend or wobble
Support ring installed
ou812 is offline   Reply With Quote
Old 06-21-2009, 08:51 AM   #33
wow that looks awesome nice job
ontherocks88 is offline   Reply With Quote
Old 06-23-2009, 11:03 AM   #34
how much machine work on the alloy pieces?
drilldeep is offline   Reply With Quote
Old 06-23-2009, 11:24 AM   #35
On my small manual lathe....about an hour,Boring takes the longest,I'D make and sell a few sets
Old 06-26-2009, 08:15 PM   #36
i am building my first crawler out of a wheely king love all of the ideas on this site will post pics when complete
viper6171 is offline   Reply With Quote
Old 07-02-2009, 02:10 PM   #37
could you make these for the axial scorpion
dunerdude69 is offline   Reply With Quote
Old 07-02-2009, 02:21 PM   #38
There are already Axial lockouts available...look at the rear axle of the ARTR and the SCX10.
Pete from Houston is offline   Reply With Quote
Old 07-20-2009, 03:28 PM   #39
thats awesome
i would do this if i needed to
tylerlong is offline   Reply With Quote
Old 07-25-2009, 09:10 AM   #40
Thanks for the great idea. I built a set this week and they worked out great. $1.53 in materials and about an hour of labor. Saved a little coin and did it with no use of a lathe. Worked out Great......
kwsmith29 is offline   Reply With Quote
