Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: Front servo mount
Old 06-19-2012, 08:32 AM   #1
Default Front servo mount
I have a wheely king. I keep breaking the stock servo saver. Not spending 15 dollars for a small piece of plastic that breaks on the smallest impact. So now I have been looking into front servo mounts. My question is I have been looking at the hot racing one. Will it work with a stock wheely king and I have strc steering linkage and will a traxxas servo and servo saver work with that set up. If this doesnt work Im giving up on my wheely king. I love running it, but this is a big problem with the servo. thank you
Diggerchick is offline   Reply With Quote
Old 06-19-2012, 09:00 AM   #2
Default Re: Front servo mount
Instead of buying servo saver after servo saver, why not save up a bit and just buy a servo thats up to the task? Buy a stronger better quality servo and there will be no need for a saver. Or just learn how to not smash into things that will break it. lol
crawler nut is offline   Reply With Quote
Old 06-19-2012, 03:11 PM   #3
i have a level3 rc axle servo mount and i like it the stock servo will fit but it is weak, at the moment i am running a metal gear high torque servo with the stock servo saver and home made steel steering links with no problems at all!
rc2008 is offline   Reply With Quote
Old 06-20-2012, 11:30 AM   #4
wyd
I been using the CKRC front servo mount on my CK. Been working great since the change and even works better than my STRC kit I had on before. I do use a super strong 419oz servo but like posted above a better servo will help stop you from breaking them.
Here is a pic of my CKRC front servo setup Comes with everything you need but the servo. Its a very heavy duty setup. With the better servo you can see I don't run a servo saver as its not needed. Now I get the most direct power I can get for steering. You will eliminate so many links of the stock setup that you will see your steering is just so much better overall with a mount on the axle.
wyd is offline   Reply With Quote
Old 06-21-2012, 09:21 PM   #5
I also have the level 3 and traxxas 2075 and it works flawless!
cr01 is offline   Reply With Quote
Old 06-23-2012, 08:55 PM   #6
will the level 3 fit with the stock wheely king? the website says it will only work with crawler conversion.
Old 06-24-2012, 07:14 AM   #7
I have the older 2 piece design witch mounts the servo closer to the axle(discontinued). Installed before crawler conversion kit.
here is a link to their site for the wheely king center and side mount. There is also a crawler king page but the part #s are the same!
HPI Wheely King Radio Controlled Rock Crawler Part!
Old 06-24-2012, 10:18 AM   #8
the wheely king and crawler king use the same axles so it should fit with no problems.
Old 07-06-2012, 09:25 PM   #9
Great fix! I was just noticing how funky the stock servo setup is. Can't wait to order my servo mount.
SoDak68 is offline   Reply With Quote
Old 07-07-2012, 02:36 AM   #10
*IF* none of the vendors here have servo mounts for the WK, I have seen them on ebay.
Dini is offline   Reply With Quote
Front servo mount - Similar Threads
Which servo mount for my front axle? acrosteve Axial AX-10 Scorpion 6 08-25-2009 04:17 AM
Front servo mount sweetride4me Axial AX-10 Scorpion 2 03-04-2009 06:43 AM
how to mount servo to front axle bigoggy HPI Wheely King 6 10-24-2008 09:44 PM
Front axle servo mount Kàlypso HPI Wheely King 3 12-16-2007 04:36 PM
Clod front servo mount? reaganreagan Tamiya Clod Buster 24 06-13-2006 12:51 PM
